Negative altitude - request for enhancement
776 10 2017-2-15
OhOhDrone
Flight distance : 526076 ft
Hi DJI team,
I ran into an issue with some of the intelligent flight modes, specifically Active Track. You can see from my illustration below where I lauched my drone at point A and started walking down to point B. Active Track stopped working with the error message being "Aircraft is too low". When I walked back up to point A and regained positive altitude Active Track would work again.
This was a real situation and here are the details. I walked up a sand dune and it was about 20m high at point A and lauched my drone. So it took point A as the base altitude. I wanted to do a side profile Active Track as I walked down the sand dune to point B where my Jeep is.
Is there a way to disable any settings so Active Track will still work in negative altitudes?
Thanks!
2017-2-15
dronist
Just simply make your starting point higher to compensate. It needs clear site to track you. It is like falling into a manhole.
2017-2-15
Heavysledz
Flight distance : 819491 ft
dronist Posted at 2017-2-15 10:39
That isn't the issue. It is that the intelligent flight mode will not let you fly lower than a predetermined altitude. The OP wants the Mavic to ignore the take off altitude and let it fly below this altitude since he is traversing downhill.
2017-2-15
bzug2TRgThdF
Flight distance : 330991 ft
Same problen with waypoints...
2017-2-15
dronist
Heavysledz Posted at 2017-2-15 10:45
Good explanation but the MP will track downward because I used it in ski slope, so again the MP needs to have CONSTANT LINE OF SIGHT to track the object so higher will have more visibility and it will track you downward but you can't dissappear on it.
2017-2-15
OhOhDrone
dronist Posted at 2017-2-15 11:07
There is constant line of sight to me as I have the mavic track me. But the problem is that it stops once I go below the launch altitude. The error message I get states that I am too low.
2017-2-15
MikeQView
wow , thought these issues were taken care of back at november time,  i seem to remember a chap flying from a balcony or something who had similar problems,  with unusual flight behavior when trying to fly lower than where he started?
2017-2-15
OhOhDrone
MikeQView Posted at 2017-2-15 15:10
I didn't have issues flying it manually. But the intellignet flight modes didn't work very well.
2017-2-15
Mavi A
Flight distance : 498980 ft
I know this doesn't solve the problem, but a work around would be to take off from the jeep, then walk and fly up the dune. Then active track back down to 0 altitude? It doesn't solve the problem but it would let you get the shot you wanted?
2017-2-15
OhOhDrone
Mavi A Posted at 2017-2-15 15:59
Yes it does. But it will be a good enhancement if the engineers can think of a way to solve this. I will be sure to keep the negative altitude in mind next time.
I didn't want to walk back up the dune. The sand was fine so I was losing a half step every time I took a step.
2017-2-15
dronist
OhOhDrone Posted at 2017-2-15 17:06
Come on a little extra step never hurt anyone!!!
2017-2-15
