What is AFC Mode?
37317 23 2017-2-15
ChrisH_Photos
Flight distance : 133694 ft
South Africa
In the camera settings of DJIGo4 (IOS) you can turn AFC mode on/off. I can find no reference to this in the manual or anywhere on Google or even this forum.
Can someone please tell me not only what it does, but also what it stands for. Obviously it has something to do with autofocus, but what exactly?
I thought of asking DJI support, but they would only ask me to reinstall the software and then send them a video of the problem.
2017-2-15
PAYBACK
Flight distance : 683885 ft
South Africa
AFAIK it will automatically focus when you start recording without having to tap the screen.
2017-2-15
ChrisH_Photos
South Africa
I'm going to answer my own question. It stands for Auto Focus Continuous. Turning it off would appear to stop the camera from constantly autofocusing.
That's a great behaviour, as I can focus once and forget about it.
2017-2-15
OhOhDrone
Flight distance : 526076 ft
ChrisH_Photos Posted at 2017-2-15 11:16
Is this only on the iOS? I don't see it on the Android. Can you please explain where you see this mode?
2017-2-15
Gateway
Flight distance : 1873806 ft
I just noticed this as well after the upgrade and yet again having to set various settings that get lost on update (DJI fix this)..
Anyhow I had it on (its on by default) and was just resetting up some lost settings where I heard the camera constantly auto focusing with this setting on.  I'm not sure how much of a good idea this may be when flying because if it see's different things it wants to focus on you may in your video see blurriness.
I'm not sure yet how I feel about it until I do a few flights..
Thoughts?
2017-2-15
ChrisH_Photos
South Africa
OhOhDrone Posted at 2017-2-15 13:00
It is in the main camera settings.
2017-2-16
Phantom Help
Flight distance : 228255 ft
2017-2-17
Fiveform 2
Flight distance : 136230 ft
It's on Android DJI GO4, as well.  I just noticed it in a flight a half-hour ago, as my phone was doing the double beep thing and the green square lighting up every so often. I was looking to see if I was hitting a control, but no - it's actually real autofocus!  Great add that I wasn't aware of!!!
2017-2-26
armoredsaint
is that why i get that beeping too, among all the other warnings and sounds?
2017-2-26
JimmyC
Flight distance : 65814 ft
armoredsaint Posted at 2017-2-26 18:15
I believe so. I tried AFC and it would beep when focusing.
2017-2-26
DRONE-flies-YOU
Flight distance : 1450594 ft
It only seems to "AFC" whilst NOT recording (Android). It doesn't focus again unless I stop recording.
2017-2-26
QuanthonyTrang
Flight distance : 419980 ft
DRONE-flies-YOU Posted at 2017-2-26 21:41
You want this, otherwise it will continually seek focus during recording.. Eg a bird flying past close by will make the background lose focus (blur in and out). If you want to change focus during recording then use "tap and focus" (turn off AFC and switch to AF).
You should look into Focus Peaking and using manual focus to create some stunning depth of field footage.
2017-2-26
Jason Lane
Flight distance : 260144 ft
Philippines
QuanthonyTrang Posted at 2017-2-26 22:04
"If you want to change focus during recording then use "tap and focus" (turn off AFC and switch to AF)."
Actually, I'm pretty sure we can still also tap to focus while it's recording in the new AFC mode. There's a notification that comes up on my screen saying something like that, but I'm not sure if I've actually tried it myself.
2017-2-27
DRONE-flies-YOU
Well yes, agreed. Just confirming the functionality.
2017-2-27
egargiulo
Flight distance : 5000 ft
but does this afc option also exist for the phantom 4? or just for the 4Pro phantom? thanks
2019-3-23
egargiulo
2019-3-23
fans18539db9
Flight distance : 1329488 ft
Czechia
egargiulo Posted at 3-23 04:06
P4 is a fixfocus.
2019-4-9
RobH2
Flight distance : 348812 ft
The more I read about AF and AFC the more I'm undecided about which one to use when doing a Panorama. I think that that AF is the best function to use for Panos. That way, the focus stays set once you've set it for the first image.
2019-6-2
fans80e36a99
Flight distance : 7438 ft
Hi everybody,
I'm new here, so I've a problem with the AFC feature and I'll explain to your attention.
I say that, if the AFC function works, the camera must refocus by itself immediately! Automatically and continuously.
AUTO FOCUS CONTINOUS, (AFC)  means that the focusing is automatic and takes place without any intervention.
Ok?
In my Mavic 2 Zoom the AFC function is defective, because it turns off when I start recording the video.
Before starting video recording, AFC works perfectly without having to press any button and also works automatically when zooming.
As soon as I switch from standby to video recording, the AFC feature stops working.
Is it normal?
Someone should explain to me why this happens.
I'm thinking perhaps I'm wrong. Perhaps I don't understand something about the AFC feature.
Thanx so muthc for any tip abt.
2019-6-11
fans80e36a99
fans80e36a99 Posted at 6-11 01:29
Hi everybody,
so... none tested if AFC stands active during video recording ??!
2019-6-12
djiuser_Gv0v7dS5FwMS
fans80e36a99 Posted at 6-12 12:17
Did you find solution? Got the same problem
2019-7-3
fans0d49d13e
Flight distance : 463832 ft
PAYBACK Posted at 2017-2-15 11:14
I have the same question, but what I found is that you have to tap the screen on mine, unless its defective, when I take off everything is blurry when recording, I tapped on the screen and it came into focus, so I don`t know if I should disable it or leave it on, but I shouldn`t have to tap on the screen everytime I fly, so I`m confused
2019-11-24
djiuser_ldNdRe5kwZsM
Flight distance : 245459 ft
Why am I having to dig to figure out how this is supposed to work? I am not going to read through the entire history of this feature to figure out how it's supposed to be working today. Need a better answer from DJI.
2023-4-5
DJI Tony
djiuser_ldNdRe5kwZsM Posted at 4-5 12:40
Hi there. Thanks for reaching out, and apologies for any inconvenience caused. AF-C (Auto Focus Continuous) mode is commonly known as continuous autofocus. This mode is used for tracking moving subjects. It will automatically re-adjust focus if you or your subject move. All you need to do is continue half-pressing the shutter button.
Note: If you take photos of dancing models, moving vehicles or anything that moves, then this mode is just for you.
We hope this clarifies your concern. Thank you, and have a nice day.
2023-4-9
