Props and storing Mavic folded....
5276 9 2017-2-15
Heyandy
Flight distance : 413009 ft
So I find that after I fold my Mavic, the props are just a bit too "lose" in freely able to spin that makes it a bit of a pain to either put in the Mavic shoulder bag, or a backpack that I have.   Right now I have "solved" this problem by wrapping a larger rubber band around the Mavic after I fold it, this keeps the props nice and tight to the body.
But here is my question, could this be putting too much pressure on the props, or worse, the shafts of the motors and going to cause long term issues?  Although I wonder if this is really an issue as without the rubber band, the Mavic is still in somewhat tight in the shoulder bag, and I suspect there is pressure on the blades and motors while in the bag.
My other option of course is just to take off the props when I go to store the Mavic, although a little more time, it isn't that difficult..   However, this also feels like I may be causing more "wear and tear" in doing so.
I'm just not a fan of the props "flopping" around when I goto to try and put it into storage.
Thoughts?
2017-2-15
TJAUS
Flight distance : 16683 ft
Perhaps apply a softer binding than a rubber band...a sock or a golf club cover?
2017-2-15
ProQuad
Flight distance : 20296870 ft
I would say remove them...as you say, it is not that hard to do.  I would be concerned that it would start to "bend" the props a bit causing them to be out of balance or not cutting the air as they should.  Maybe try a Velcro strap?  You could make it as loose/tight as you feel it needs to be.
2017-2-15
DroneFlying
Flight distance : 10774613 ft
I like this guy's videos and he has a good suggestion for this (starting around 7:00): use a velcro strap instead of a rubber band.
2017-2-16
fans90d4f438
Flight distance : 451335 ft
Sounds like you need that vinyl bag from DJI designed to store the mavic in
2017-2-16
Heyandy
DroneFlying Posted at 2017-2-16 03:09
DJI Mavic Pro Hints and Tips
Thanks for the video, there is other good stuff in there...   I have a checklist I need to add some of his suggestions to...
2017-2-16
Heyandy
Thanks for the replies and comments..   I have some Velcro straps around the house, I am going to use those.
2017-2-16
DJI-Ken
Flight distance : 1515312 ft
I use a large rubber band and it's just snug and it will not cause any issues.
2017-2-16
SixtyMike
Thanks for posting the vid.  Great tips and suggestions.
2017-2-16
eddieNoob
Puerto Rico
SixtyMike Posted at 2017-2-16 11:45
All of Peter Homer's videos are the definition of punctilious.
2018-1-30
