Case or backpack for Inspire 2
4542 11 2017-2-16
Bitt3rsun
Flight distance : 189469 ft
Within 8 weeks I am traveling to Iceland by plane. I am looking forward to this trip, but my concerns are about my Inspire 2. How on earth can I safely travel with this amazing drone and I mean safely for my drone. I found thanks to you guys beneath cases, but maybe there are other or even better cases. I found some peli cases, but the don't have custom fit cases. I don't feel like cutting the inner stuff and hoping that is being ok for a safe journey! The Inspire 2 is to big for a carry-on luggage, so it must be checked in.
http://goprofessionalcases.com/s ... ire-2-backpack.html
This is a backpack, but it is not in stock. Emailed about eta.
and
http://goprofessionalcases.com/s ... s/dji-insp2-l1.html
This hardcase is in backorder, available in landing and traveling mode. Emailed about the eta
Let me know if there ar better or available cases out there.
2017-2-16
Bitt3rsun
I also found this case:
http://www.hprc.it/en/hprc2780w- ... _ins2-2780w-01.html
Also not in stock..
2017-2-16
wild giles
Flight distance : 908094 ft
I just bought the hardshell case for inspire 1 & 2 backpack.
The case that comes with the inspire 2 fits inside quite well.
With a little bit of added foam underneath it will not move around.
2017-2-16
fans218d2672
I use the Peli 1640.  The standard box is placed inside perfect and the top has plenty of room for extra things.
2017-2-16
Mike-the-cat
Flight distance : 22822654 ft
Singapore
Thanks. The backpack looks good.
2017-2-16
RichJ53
Flight distance : 1837356 ft
I like the looks of the backpack option.  I am sure more items will pop up in time as more I2's are sold
Thanks for sharing
Rich
2017-2-16
Bitt3rsun
I bought a Peli 1640. The nice thing about this case is, that it fits the original DJI case. So the original DJI case just slides in the outer foam ring. Now I can lift the lit of the DJI case, while the bottom remains in the Peli. This could be a deal breaker for others to. I bought the case for around €360,- ($380,-).
2017-2-18
Zane Isaac
Flight distance : 8712549 ft
Lowpro has sweet backpack for the inspires now.
2017-12-19
fansa84fe8a4
Flight distance : 3 ft
Not crazy about the backpack as it has too much flex for the glued and fragile arms and feet of the Inspire 2.  If someone sits on it or drops a corner of the backpack, that might be all she wrote.  I'd go for a hard case any day over a soft one.
2017-12-19
Adam Papworth
Flight distance : 2054268 ft
Has anybody broken there inspire 2 while having it in a backpack?
2019-9-17
Joecos
Flight distance : 3294770 ft
I have a similarsetup..  Its a dual purpose travel gear.  A GPC backpack inside a Pelican 1640 case.
The Pelican is for airline travel and the GPC backpack is when im out in areas where the shell case will not work.  I remove the middle foam fom the peli but surround theBackpack with foam on sides, top and bottom.   You will be in situations where you will have to sherpa the backpack but its better than lugging the peli.
I'll try to post photos when i get home.
2019-9-19
Joecos
20190916_125738 Resize1.jpg 20190916_125925 Resize2.jpg 20190916_130416 Resize4.jpg 20190916_130920 Resize3.jpg Here are the Photo's.
GPC backpack inside the Pelican 1640
2019-9-19
