0Kajuna0
![](https://forum44.djicdn.com/data/attachment/common/aa/common_14_usergroup_icon.png) Second Officer
Flight distance : 267126 ft
New Zealand
lildevilx Posted at 2017-2-17 03:44
On Androids, you have to wait for it to prompt and ask you that, this connection doesn't have any internet access, continue to use it? Click yes and it should allow you access to the network which then will allow it to connect to the Mavic. If the 6P doesn't give you that option... well then Google goofed up, works on my OnePlus3
(but that is the problem for sure, Android phone are silly like that sometimes)
You are right. The problem in my case is that next to the "This connection doesn't have any Internet" is a "don't remind me again" checkbox. I assumed if you clicked that, the connection would always work. But it doesn't. DO NOT check that option. You ALWAYS have to wait for the prompt and accept the connection.
There might be a more permanent solution. Not sure.
The other problems the Wifi connection gives me are:
- Many camera settings change without reason (focus peaking, overexposure warning...)
- Tap to focus not working. Even when the onscreen sticks are disabled.
Other than that, now it's usable. |
