Battery stored at 1-2%
997 8 2015-2-21
zubeko
Hi everyone.My name is Bart and i'm new on the forum.
Yesterday i have received my Phanton 2 V2 which i bought on the official website
I've took it out of the box and found that the battery was deeply discharged, when plugged to the PC it showed as 1%.
I'm a little bit worried about this because lipo batteries should be stored at 30-50% right? And i'm not sure for how long it was like that on the warehouse etc..
What do you think guys? Would it affect the life/performance of the battery?
Should i speak to DJI to replace it for me?
2015-2-21
godfrey.dayo
China
The manual says it should stop discharging at 8.4 Volts .... What is the "Current Voltage"?
2015-2-21
Ploug
Denmark
I would ask for a new battery since Lipo is dangerous, and yes it could affect your battery lifetime
2015-2-21
George1124
Did you put it on the charger and leave it on for about 2 hours?
2015-2-21
zubeko
i've charged the battery and it worked fine for 3 fully charges - discharges
today i went flying with fully charged battery and after 10 minutes red lights started to flash so i went home and plugged it to the PC
look what it says:
Percentage of life: 0%
Discharging times: 32517 times
battery dead after 3 uses?
2015-2-26
PanamonCreel
Mexico
zubeko@gmail.co Posted at 2015-2-27 01:20
today i went flying wi ...
Likely the smart board defective, get it replaced.
2015-2-26
siweckipawel
Flight distance : 57070 ft
Poland
yes, I see it is the new V2.0 battery, it supposed to be better than previous model, but it is the same or worse...
2015-2-26
zubeko
i will give them a call and ask them to replace it for me
i don't want to end up with power cut out in the air or something
2015-2-27
gnixon2015
is it not possible that the 'very low state' it got to (per his comment in the original post) has caused the battery to be permanently affected?  his OP said 'battery deeply discharged to 1%'.  i thought that COULD cause a battery to stop functioning properly (which seems like the result he is seeing could be a symptom of that? no?
2015-2-27
