AG0N-Gary
Flight distance : 700846 ft
MavicMule Posted at 2017-2-18 16:35
Pg 27 of manual says moderate heat will be emitted during discharge process. Some of the tutorials on YouTube said same thing, but if it's in a case, heat might get trapped in warmer climates. The cracks in the OPs picture looks like heat stress. I haven't,personally had the cracks because my LT stored batteries are below 65% charge.
My temperature comparisons (measured with IR thermometer) were made with one battery on self discharge and the other at 50% from the week before. They were removed from my closed wheeled case, surrounded by the normal foam segments, each in their separate but identical compartments. The one that was discharging had been doing so for a few hours, and the other one had been discharged the weekend before. When I pulled them both out, I immediately measured their outside temperature at 1.5 deg F differential on the warmest surface. Leaving them on the desk over the next couple of days, they remained about 1.0 deg F differential until I quit checking them. I suspect the differential tapered down as the discharging battery got closer to its 50-65% charge state, where both of mine seem to quit discharging. |
