DJI-Jamie
Flight distance : 112405 ft
Nodch Posted at 2017-4-18 07:09
Hi all,
I too have a problem with the HDMI Module. I can install it fine, afterwards to the firmware upgrade and use the HDMI out port with an external monitor.
My problem though is, with the normal connection board, I am able to use my Oneplus 3T and Nexus 7 (II) devices without any problems. With the HDMI module installed, all those devices fail to connect with the DJI Go app and only my iPhone works.
Just to clarify, does the USB port seem to provide power to the devices? I would recommend performing the following RC combination to reset the RC as well:
* Turn on the controller, and the aircraft should be off.
* Press C1, C2, and shutter on the controller then turn the controller off.
* Turn on the RC, then the aircraft.
See if this helps. You may want to relink the RC to the aircraft as well to ensure the communication between the two are solid, which I would recommend performing a manual relink with the following combination:
* Turn on both the aircraft and the controller.
* Press C1, C2, and the record button on the controller, then the controller will beep like D-DD. This may take a few seconds of holding it.
*While holding the buttons, press the wheel on the right side of the controller and then the first light of the controller will become blue and it will constantly beep DDDD.
* Use a pen to click the linking button on the aircraft and hold for 3-5 seconds, and then take the pen off the aircraft and wait, it will be linked soon.
