Camera not transmitting image - Gimbal working properly
2029 8 2017-2-18
aaronn
Colombia
Since yesterday the camera won't transmit an image. The gimbal moves and works fine, and I'm not getting any error messages, just the phone screen is black. Using a Galaxy S6 and tried on an iPhone 7 too.
Can a cable or pin have come unplugged? Currently out of the country so can't call DJI, and would love to get it back up and running.
2017-2-18
dronist
It happened to me once after I started the AC  with the Gimbal lock on.... Just be VERYYYYY careful when you do the following:
With the AC OFF... gently hold the camera part and move it backward to opposite side ALL THE WAY to the end but do it gently and don't force it but take it all the way to the end limit.
Then turn the RC/AC/APP and see if it worked. I had to do it couple of times but it worked for me and never had an issue again.
Good luck and let us know...
2017-2-18
aaronn
Colombia
dronist Posted at 2017-2-18 19:42
Thanks, tried that a bunch of times to no avail.  Do you mean just pushing the entire camera setup towards the back of the AC until it touches that vent part?
Also, is this loose piece of plastic normal?  Should I try to remove it?
2017-2-18
aaronn
Colombia
It wouldn't let me edit the post to link the pic properly... here it is:
2017-2-18
Defender4he1
Flight distance : 466 ft
aaronn Posted at 2017-2-18 21:39
I think that piece of plastic is a ribbon cable that appears to be broken but hard to tell from pic
2017-2-18
dronist
Oops.... That is the cable ribbon that control the camera sensors/image. Like defender said it is hard to tell if it is an extra extension coming out of the ribbon or it is broken. If it broken than you need to contact support. If it is NOT you still need to contact support to see if it is a defect.
2017-2-19
aaronn
Panama
Here is another pic. It looks like a piece of extra plastic just peeling off.
I guess it'll be going back to DJI when I get back stateside.
2017-2-19
aaronn
Panama
aaronn Posted at 2017-2-19 14:13
Whoops. Take 2. Hopefully it works this time.
2017-2-19
aaronn
This didn't help me, but maybe it'll help someone else.  What DJI recommended:
Dear customer,
Thank you for contacting DJI Technology.
To resolve the No Image Transmission Error issue. Please follow the steps below to troubleshoot for it:
Please remove your SD Card from your aircraft.
Please change the Image Transmission Settings (Channel: Auto or Custom) from your DJI Go App.
Please attempt to fly on a different location with no interference such as buildings, trees, hills, magnetic interference and etc.
Please change to a different USB cable .
Please use a different mobile device that DJI recommended.
If the steps fail to resolve the issue, please provide us the following details:
* A screenshot of the current firmware on your ABOUT page located in your DJI Go App.
* A screenshot of the error message encountered.
2017-2-21
