BREW69
Flight distance : 435614 ft
I've had this, scared the s**t out of me. Received Mavic on 16th Feb. My first flight was indoor and was fine (Had return to home turned to hover). Later that day took it to local field, changed settings back to return to home. After a minute of being in the air, stated Aircraft Disconnected. No sticks or buttons on remote or phone had any effect on Mavic. Mavic hovered there. Then had a vibration and it kicked back into life. Kept on landing it, turning off, restarting it. Compass, etc. No luck. The last time it went to return to home, (I nearly had a heart attack because I forgot I put it in rth.) Came down ok. Took home and just looked everywhere for an answer. Came across Airplane mode solved it somewhere. I was using Samsung S7 first day. Took it to work following day, had same problems with Note 4. Then remembered about flight mode, and i've had no problems. I've stuck with Note 4 aswell, had to download dji go 4 aswell as having dji go on it for phantom 3 adv. Was thinking this might cause problems but it hasn't so far. The only downside that I can think of, is that maps won't work properly if in previous unknown area |
