Question about GPS to Atti
438 5 2017-2-19
Stacky
New Zealand
If I take off in GPS mode with home point recorded and then switch to Atti but later in a flight switch back to GPS will the original home point still be the one used to return home?
2017-2-19
Palladous
Flight distance : 102185 ft
Yes - I have done that.  There was a problem in android Go App 3.1.2 where the home point would jump to a far off random location. That appears to have been fixed in 3.1.3.  iOS never had this problem.
2017-2-19
Phantom Help
Flight distance : 183694 ft
When manually switching to ATTI mode, your Phantom is still able to use the GPS data if needed. That'll allow it to return back to the last marked home point if RTH is initiated during the flight.
2017-2-19
Stacky
New Zealand
Thanks for that!
2017-2-19
dronist
But I will always take a peak at the map and verify the location if not correct point to the remote controller.
2017-2-19
blackcrusader
Flight distance : 689774 ft
Taiwan
dronist Posted at 2017-2-19 20:18
Plus you can always use your RC and rotate your drone to see your location.
2017-2-19
