Gimbal motor overload warning
1361 8 2017-2-19
Teamrealtree5
Hello,
Today I noticed my first gimbal motor overload causing the camera to rotate tilt sideways and down.  It was slightly windy and I was in sport mode making quick movements.  How common is this and is this normal ???
2017-2-19
DJI-Thor
Flight distance : 13602 ft
Hi, it's normal for it to show up if you're close to the limit of the gimbal.   But does the warning go away?
2017-2-19
Teamrealtree5
DJI-Thor Posted at 2017-2-19 20:11
Yes, the warning goes away after the camera acts like it's falling off the p4p.  It resets then appears to be fine would only do it if I had a head wind and turned left.  The camera would rotate and a quarter turn clockwise
2017-2-20
leonardrosser
Indonesia
Hi I also have gimbal motor overload issues. the gimbal just tilted to the max when turned on. There was one time I forgot to remove the foam pad protector in gimbal when turn it on, and just remove it right after. It begin the problem with gimbal motor overload, but when i poke the gimbal it just went normal for 2 flights. but now it is almost permanent and IMU calibration with gimbal calibration sometimes cure it but must be done every time I start the aircraft.
Has anyone facing a similar issues?
2017-2-22
SkyMemories
Flight distance : 139967 ft
Malaysia
Phantom gimbal making me headache... =(
2017-2-23
Teamrealtree5
Here's a clip
2017-2-24
Teamrealtree5
Teamrealtree5 Posted at 2017-2-24 18:34
Here's a clip
https://www.dropbox.com/sh/xlzqp469clczv6x/AAA8-jNxyojxmr5lIueXQnawa?dl=0
2017-2-24
Teamrealtree5
My drone is a p4p btw
2017-2-24
Teamrealtree5
https://youtu.be/MFc2IN63j-4
2017-2-24
