Mavic sensor warning
843 5 2017-2-20
Nunno
Flight distance : 224469 ft
Hi,
I have been getting ultrsound sensor warnings boxes flashing up on the screen whilst flying my mavic. After getting this warning for a third time i have noticed that one of the sensors beneath the mavic seems to be loose/floating around in the mesh housing.
Could someone please let me know if this a common thing or a rare thing.
If it is not meant to be then how do i go about getting it fixed?
yours hopefully
Nunno
2017-2-20
Nunno
Could this be the reason it is toilet bowling, loosing GPS etc?????
2017-2-20
Griffith
Flight distance : 98537 ft
The ultrasound system's purpose is primarily for landing and for accurate height measurement up to a few meters.  If you have a loose receiver or transmitter element, erroneous results will occur.  While this may confuse the Mavic into taking some strange movements, it should not effect normal operation of the GPS.
It the US system is broken, you may have trouble landing or get an erroneous VPS height measurement showing up in GO.
If it's loose get it fixed.
2017-2-20
Angelo26
Flight distance : 799718 ft
Austria
Could You post a photo of the loose sensor ?
2017-2-20
dronist
Did you receive the warning while landing or only while flying?
2017-2-20
DJI Natalia
Flight distance : 318 ft
Nunno, it's appreciated if you can provide us more information as mentioned above, we'd like to help you check it.
If it's not working properly, we'll create a case for you and guide you send it in for evaluation.
2017-2-21
