Ronin freak out help!
1371 2 2015-2-21
paxpincer
New Zealand
Hi all, cant find anyone experiencing these problems, would really appreciate any thoughts/help.
So right out of the box, ive changed the smaller arms for the larger ones to accomodate an FS7.
Was rather involved but am positive ive done it correctly.
Once it was balanced, turned it on and it totally freaks out then shuts off.
The pan/tilt etc twists and turns, rolls over to its limits and keeps smacking against its limits trying to roll more (hope that makes sense).
I tried without my camera on also as I was paranoid about getting a knock or falling off but the same thing happens.
After a while I think the motors shut off and the battery blinks.
Ive tried to calibrate in this condition which doesnt help and pressing the autotune stability does nothing-pressumably because the motors are off.
Any ideas?
Please dont respond saying you've probably wrecked it, id be very surprised if its anything ive done wrong, have checked over thoroughly.
Is it defective?
Thanks
Peter
2015-2-21
tahoejmfc
where did you get the longs arms? I cannot find them
2015-2-25
DJI-Dboy
Hi, Peter,
Does any part of the 'T-type' cable broken after installation? because replace the long arm is quite a complex work.
Have you done 'calibrate system' after the replacement?
2015-2-26
