Phantom 3 advanced video vibration
iMeMoz
Flight distance : 298720 ft
Finland
I have some problems with my drone footage. Few days ago everything was perfectly fine, but now suddendly video footage vibrates. I havent done anything to my drone since it worked perfectly, problem just came out of nowhere! I have done IMU and gimbal calibration, also changed propellers to new ones, but didnt help :p. Any tips? Any help will be appreciated!
2017-2-20
Cetacean
Flight distance : 2528264 ft
Aloha Moz,
     Have you tried to see if it will happen with other frame rates?  Sometimes the frame rates do not match well with other (unknown) conditions.  Sometimes firmware updates can fix the problem.
     See what you can find out with different settings.  If all the settings give you the vibration, then it is likely a camera problem.  If only 48 fps that is causing the problem, then maybe firmware can help or it may go away with different environmental conditions.
     Hope this helps!
Aloha and Drone On!
2017-2-20
iMeMoz
Finland
Cetacean Posted at 2017-2-20 15:00
Aloha Moz,
Hi, i havent tried any other than 48fps, i will try tomorrow. And everything is updated drone, rc and go app. Thanks for tip!
2017-2-20
iMeMoz
Finland
another video, you can see vibration much better on this one. Look at 0.14!
2017-2-21
Manny-pr
Flight distance : 10933205 ft
Puerto Rico
iMeMoz Posted at 2017-2-21 13:25
https://www.youtube.com/watch?v=3WXW0tc45to&feature=youtu.be
In my case I had that problem. I solved it by changing the white damping rubber balls & anti-drop pins kit. Maybe you can try it.
2017-2-21
iMeMoz
Finland
Manny-pr Posted at 2017-2-21 15:42
I will try it!
2017-2-22
Fistel
Flight distance : 491158 ft
I´m interrested too, if this is the solution (rubber balls / pins). But could it not be the cold temperatures? I notice a light vibrating when flying in the cold. As the quad gets warmer, the vibrations stop.
2017-2-22
iMeMoz
Finland
Fistel Posted at 2017-2-22 02:35
Well at least for me vibration occurs whole´flight, so i dont think that low temperature is problem.
2017-2-22
phantomdust
Greece
Low temperature could affect their physical properties(rubber is "harder" when cold). And by this I mean their resonance frequency. This means that they filter different vibration frequencies depending on their temperature.
2023-6-5
