Aardvark
Flight distance : 384432 ft
Which display device are you using, I suspect an Android device ?
If so then check the firmware build of the RC, and if it is at V1.8 you could try rolling it back to V1.6:-
Connect display device (with wifi connection) to RC and power both up (aircraft off).
Run DJI Go, on initial screen (where it displays aircraft type etc) at top right hand corner you will see a 'graduation hat' icon (or perhaps three lines). Hold your finger on that for about 5 seconds and release. You should now see a black screen appear with an option to roll back RC firmware. Make sure RC is well charged, takes about 5 minutes or so. Power down when complete. Restart all and check all working, you may need to relink RC to aircraft. |
