24ctDrone
I've had the Pro+ now since it first came out. The firmware is up to date. I have calibrated the compass done an IMU calibration and calibrated the gimbal, several times.
Everything seems in great working order (except 4K video transmission), all diagnostics check out and I get no error messages. However the horizon is clearly off every time I fly.
So I have looked in to the issues a little bit and I did one simple test. I put double sided tape on the gimbal to counter-weight the downhill side. I used tiny washers and went from very light to medium light. I eventually found the sweet spot and have been getting much better results. When studying the gimbal, the weight distribution on its roll axis seems to be too heavy on the drop down camera support side. I wonder if this is part of the problem others are having as well or if it is just mine. I also noticed that my drone has an issue with the battery well. The battery is not completely flush with the well. I'm wondering if there was a batch of drones with a few minor engineering issues. Anyone else have similar symptoms?
