Mavic Long Range Battery Mod
18145 16 2017-2-21
fans90d4f438
Flight distance : 451335 ft
Anyone here tried this yet?
http://www.uavmods.co.uk/
2017-2-21
fans90d4f438
2017-2-21
geofox784
Flight distance : 1482175 ft
Interested in this as well.
2017-2-21
Fractures
Flight distance : 635531 ft
Sounds like a great idea until I get a battery failure and my Mavic drops from the sky and is no longer covered under warranty.
"Includes a LED light so you know when to connect the aux batteries" If i have to stop flying and connect the batteries then whats the point?
2017-2-21
MacIak
Flight distance : 3419 ft
Ooohhh!!! Love these mods!! First need to extend tx range though. Bl00dy CE output!
It's too bad that these mods make the mavic ugly. It s such a pretty machine.
2017-2-21
fans90d4f438
Fractures Posted at 2017-2-21 11:38
Based on the video, I believe the LED lights up after you've powered on the MAvic, IMU initialization has occurred, etc. THEN once all systems are ready, you connect the aux battery prior to liftoff.   Note the range the guy in china obtained in the video posted in this thread.  I didnt see his mavic dramatically "fall from the sky".
Admittedly this type of mod isnt for the skittish.  It's for those looking to push the boundaries/limits.
2017-2-21
MacIak
How the heck does one manage that kind of range though? 9 km and all those buildings around? Still good and solid signal!!
2017-2-24
fans2af8f452
Flight distance : 66831 ft
What do you mean fall from the sky???
I have this set up and also the antenna modd that tony sells .
you trun on your mavic ,then you plug in you 2 other batteries,
and you off .....at this point, it would take 3 batteries to fail, before
it fell out of the sky......
2017-2-24
fans90d4f438
fans2af8f452 Posted at 2017-2-24 05:10
glad you showed up!
Can you let me know which batteries you have added?
Also, do the additional batteries simply allow the main battery to discharge at a much slower rate when flying? Or does the mavic use up the aux batteries first..then the main battery kicks in?
Also, how is the DJI GO battery meter affected by the additional batteries?
2017-2-24
jkantiques!
fans90d4f438 Posted at 2017-2-24 06:08
glad you showed up!
I'am using 2 thunder power prolite 910 mah 3 cell, each weigh  69 grams.
they all discharge simultaneously when turned on...
Kevin
2017-2-24
fans90d4f438
Thanks!
How many minutes total flying time are you getting?
2017-2-24
jkantiques!
fans90d4f438 Posted at 2017-2-24 19:23
Thanks!
27-30 mins, depending on how far you want to push it....
2017-2-24
MacIak
Curious about the antenna mod!! You have a link?
Thanks
2017-2-25
devGOD
Flight distance : 200577 ft
all that for about 6mins?  the avg flight time on the Mavic battery is 21-27 mins
2017-2-25
fans90d4f438
Ive never gotten a FULL 27 minutes flight time from a mavic battery.
And even if its 6 minutes more, thats ~ 20% increase in flight time.
2017-2-25
jkantiques!
MacIak Posted at 2017-2-25 06:06
Thanks
Sure...paul from FPVCUSTOMS.com
2017-2-25
MacIak
jkantiques! Posted at 2017-2-25 15:00
Thanks bud! Are these the Jagi ones? Im using the itelite dbs 02.2 at this time. No joy, not getting more than stock with these.
2017-2-28
