theshwin
I upgraded the firmware on the ground system to the latest version because it wasn't connecting with the air system. However, the air system is currently running V1.1.40 and I am trying to upgrade the firmware to V1.1.50. I have used the second latest and the latest version of DJI Assistant 2. The Assistant detects the air system fine but when I try to upgrade it, the download bar flashes briefly to 100% (sometimes can't even see this happen) and then says Update Failed and shows a 0% bar. All the connections are fine and the air system is powered one as normal. Screenshot of the error is below.
Update Failed screen
If anyone has any idea how to fix this, please help. Really need to be able to use the LB2 and it hasn't worked yet.
