pcdev2004
i have an Phantom pro firmware 1.19 ,not updated it al all then one day esc error , took it apart and checked it over, could not find anything wrong , tested it with out the top screwed down , it started !!
no esc error , screwed it back together same again esc error ARGHH , changed all the motors over , same esc error !
then purchased a NEW MAIN BOARD ( very costly ) that contains the esc's , installed it in the uav powered it up , guess what ESC error still !!!! , firmware on the board was 1.1 , upgraded to 1.3.20 upgrade went ok , powered it up still esc errors,So to recap .
so we have changed about everything there is to change ,
to start we did not do any upgrades and the esc errors started , when i opened it up it started !!! , screwed it back down , esc error .
replace the board , still the same ,replace ALL the motors still the same .......... this is stupid .....
changed batteries , .......... there is nothing else to change !!!!! ..
not found the problem yet !
