Phantom 2V+ drifting a tad
1113 10 2015-2-22
rrbcap.gmail
So I've logged probably a couple hours on my phantom since I purchased it a few week ago.  One of the things i have noticed is the phantom wants to drift left after taking off.  I can steady it and it still wants to drift.  It drifts probably about 5-7 feet but after flying it for a few minutes it seems to work itself out.  I always calibrate the compass before flight, and make sure I have at least 8 satelites.  When I purchased it i did recalibrate the compass and IMU(??) but was a little concerned that it wants to drift a little.
Is this common or can someone explain to me what else I may be able to do?  I love the phantom and it is so much fun to fly!  I ended up reprogramming it in NAZA Mode and like it so much better.  I'm surprised it doesn't come shipped in NAZA M.
Thanks everyone!!
Ryan
2015-2-22
gary.ok
Pretty normal. Mine does the same thing. Takes it a few to get its bearings and hold position.  I just push it up high enough where the drift won't hurt anything and it will hold and move back in a few seconds. Nothing to worry about as far as I know.
2015-2-22
johnwarr.live
Flight distance : 6467 ft
Yeah the tolerance for GPS hold is within 1 metre vertical and 2.5 meters horizontal, so its normal to drift a little in a hover.
2015-2-22
rrbcap.gmail
Thanks for your reply, John!  That makes me feel a little better.  How often do people hook up their DJI to the computer and recalibrate that way?  was just concerned because it always wants to go left.  Not any other direction.
2015-2-22
Northofthe49th
The key to the calibration is ensuring you are on a completely level surface and with no electronic interference around.
There are a few threads on here where users commented about a similar drift and they ended up putting paper shims underneath the legs during calibration (literally ie. 4, 5 sheets etc.) and after several attempts found their perfect spot so to speak and things leveled out great for them from there.
2015-2-22
johnwarr.live
That would sound like an IMU calibration is needed, the IMU needs to know when its level, so make sure it is done on a completely flat surface and away from any metal.
Personally I only hook up to the PC when there is a firmware update to do.
2015-2-22
markus2015
I callibrate my IMU and RC after a firmware update. You should also do it if the phantom acts weird. When callibrating the IMU make sure that the surface is absolutely level and that you're not on top or next to large metal or magnetic objects.
2015-2-22
rrbcap.gmail
Here are my settings on the IMU.  Everything looks ok.  There are gain settings as well.  I take it if I want the phantom to climb faster or move faster i can adjust those #'s.  I need to check the manual but is that recommended?
2015-2-22
johnwarr.live
If you hover your mouse over the ? it will tell you all about the readings.
Gains should be left alone, the basic ones are for automatic flight and hover, the attitude gains are for control, but only effect the right stick and unless you know what you are doing I would leave them alone too.
2015-2-22
rrbcap.gmail
johnwarr.live Posted at 2015-2-23 03:21
Gains should be left alo ...
Thanks.  I started researching this and I think I'll leave it alone.  If it ain't broke don't touch it!  faster forward speed would be cool though.  I know faster speeds can be achieved in Manual mode but it's also easier to crash.  anyone to get a little more forward speed?.
2015-2-22
johnwarr.live
For me a flying camera should be slow and as smooth as possible, but if you want to be a speed demon then go for it.
2015-2-22
