Punchbuggy
Flight distance : 483166 ft
Hi. I got a little confused by the earlier posts (it's been a big day), so I thought I'd clarify.
The base unit of each of those is identical for use with the P4P (and only that model - not the P4 - as it offers 2.4 and 5Ghz dual band transmission which only the P4P has).
One incorporates a FIXED tablet device which runs on a DJI developed Android build. This will come with the P4P if you order the P4P 'plus' version. Personally, I would encourage buyers NOT to go with this version, as the tablet build is locked i.e. you can't install your own applications including third-party apps such as Litchi, Autopilot or Hangar360. The tablet component is therefore not available to be used for general use away from the unit.
The other requires you to add your own smart device - either phone or tablet, Android or iOS - to run the app of your choice with. This version will come with the P4P 'standard' version.
That's why you'll see the P4P at a price much cheaper than the P4P+.
