What Micro SD Card are you using?
1354 16 2017-2-24
armoredsaint
Since I just got my Mavic on Weds, it's still the OEM Lexar 633x 16gb - seems to shudder somewhat on recorded video.
Recommendations on a much better 32 or 64 gb one?
2017-2-24
fans8b209188
Well, technically it shouldn't. Sandisk Extreme would do nicely, the latest of that card will do 60MB/s vs ~10MB/s for the Lexar. I am recording 4K@30fps with no issue.
2017-2-24
hallmark007
Flight distance : 9827923 ft
Sandisk extreme pro 64gb
2017-2-24
devGOD
Flight distance : 200577 ft
SanDisk - Extreme PLUS 128GB
2017-2-24
maxhan
devGOD Posted at 2017-2-24 15:53
Can you actually use all of the 128GB on the Mavic? Its spec sheet indicates a maximal capacity of 64GB.
2017-2-24
maxhan
Extreme PLUS or PRO seems like an overkill to me, at least for the Mavic as its maximal video bitrate is 60 Mbps which is 7.5 MB/s on write (plus some overhead).
Sandisk Extreme90MB/s
2017-2-24
maxhan
I hit submit by mistake and it won't let me edit after 2 minutes.
Sandisk Extreme 64GB - 90MB/s Read, 60MB/s Write
Sandisk Extreme PLUS 64GB - 95MB/s Read, 90MB/s Write
Sandisk Extreme PRO 64GB - 275MB/s Read, 100MB/s Write
So they will all handle video recording fine, the only difference to you will be transferring video to your computer. For 64GB of file, it will take ~11minutes for the Extreme and ~4 Minutes for the Extreme PRO. You will have to decide if the cost would justify the added benefit.
2017-2-24
armoredsaint
this is embarrassing, but how do i change the video resolution? yes i haven't read the manual i can't find the settings, some things don't seem logically placed.
2017-2-24
devGOD
maxhan Posted at 2017-2-24 16:04
yes all128gb (i think its like 119gb) is available for use. read / write is 95mb/90mb pretty fast card and reliable
2017-2-24
devGOD
armoredsaint Posted at 2017-2-24 16:44
here's how you change video resolution... i'm in photo mode but select video and the options will change accordingly
2017-2-24
armoredsaint
devGOD Posted at 2017-2-24 18:11
thanks!
2017-2-24
tellus1
Flight distance : 105551 ft
I use sandisk extreme pro 64gb
2017-2-25
Bpup
Flight distance : 192343 ft
Norway
tellus1 Posted at 2017-2-25 03:28
Ditto. I did get a sd card warning the first time putting it in, but a format made it go away.
Love it!
2017-2-25
Samoth
Flight distance : 95640 ft
Belgium
A 64 GB Samsung EVO
2017-2-25
SrMi
Flight distance : 3425 ft
How do you know that it shudders? Playing recorded video on my Mac Pro shows shudder but that is caused by computer not by recorded video. E.g., often using VLC instead of Quicktime player eliminates the shudder. Also when exporting/compressing to Youtube 4K that shudder (visible in Quicktime player) disappears.
2017-2-25
MavicMule
Flight distance : 6329 ft
Sandisk Extreme Plus 32g & 64g, and Extreme Pro 64g.  They work very well for now.  I'm still in pre edit mode, so stay tuned.
2017-2-25
Loganx1121
Sandisk extreme 64 GB
2017-2-25
