Advanced hub is charging batteries simultaneously
4381 14 2017-2-24
softgrapes
I have the new advanced hub with a phantom 4 charger. I am not complaining but I thought his hub still charged the batteries in series. Mine is charging 3 simultaneously.
2017-2-24
SectorDrone
Flight distance : 1114649 ft
How ?  update FW of the HUB ?
2017-2-24
devGOD
Flight distance : 200577 ft
just guessing but it could be the amount of power that is being outputted from the wall socket
2017-2-24
alirz5
Flight distance : 609833 ft
Well that is cool Though i dont think that is normal..
2017-2-24
rparge
Flight distance : 173852 ft
You're using a Phantom charger, yes? If so, does it do this with the Mavic charger?
2017-2-24
armoredsaint
in before the fire
2017-2-24
Daroga
Flight distance : 3517287 ft
Everyone should be aware that there are TWO models of the Mavic Charging Hub. The Mavic Charging Hub shown here -> Mavic Charging Hub, is model number M1CH-S and IS NOT compatible with the Phantom 4 charger. DO NOT try this.
The other hub, the ADVANCED Charging Hub is shown here -> Mavic ADVANCED Charging Hub, costs more and is model number M1CH-P and IS compatible with the P4 charging system for faster charging...
So please be aware of which hub you have before connecting it to anything other than the standard Mavic Charger....
2017-2-24
softgrapes
Yes I am using the advanced hub (M1CH-P) with a p4 charger. I didn't try it with the mavic charger to see if it did the same thing or not. I'll do next time.
Just concerned since according to DJI this is not the expected behavior. Or it is and they got the wording wrong in the product description. After all, when it was first announced simultaneous charging was one of the features.
2017-2-24
Daroga
softgrapes Posted at 2017-2-24 19:49
The manual says that the Advanced Charging Hub charges batteries in stages, making charging multiple batteries faster.... -> Click here to see the Mavic Charging Hub Guide, look for page 6...
So if you have the M1CH-P, then four Mavic batteries should take about 2hr 30mins....
2017-2-24
alirz5
Well if his video is real then we can clearly see all batteries being charged simultaneously...
2017-2-24
softgrapes
Daroga Posted at 2017-2-24 20:00
So I guess this is expected behavior then?
2017-2-24
Videolester
Flight distance : 466624 ft
Saw another post that stated that if batteries (by chance) have the SAME voltage when put on the charger, those batts will charge simultaneously.
2017-2-25
Brutus
Flight distance : 124304 ft
Videolester Posted at 2017-2-25 20:57
I can confirm that, had it once with two batteries connected. (with the out of the box Mavic charger and hub)
2017-2-26
chippie
Flight distance : 12976 ft
I believe it is simply that as Brutus said, the 2 batteries were at that level, I have also seen this happen even with the Mavic brick well that is if the OP is using the non Advanced Hub? The Advanced Hub only became  available a few weeks ago at a premium and that does charge 2/3 batteries at the same time. Also I would be cautious as I am not sure if you should be using the Phantom Charger with the non Advanced Hub but then again as it is only passing voltage and it seems to work then it does not look like an issue :-)
2017-2-26
Eric13
Flight distance : 12614816 ft
Is it ok to keep the batteries in the charger for a few days before next flight or should they be removed after full charge?
I have the original DJI P4P charger hub for 3 batteries and would like to keep them sitting in there...
2017-3-3
