SnowBirdNL
People shouldn't be so rigid when coming to some regulations, as they are not as clear cut as they may seem.
Example:
- I live in a small city with a "somewhat" serious airport at the end of the city.
- This city has MAJOR changes in elevation from place to place, compared to the other extremes like the prairies.
- Canada says to be 9km from airport, and maybe this makes sense on prairies as of course is related to planes descending in that airspace.
- The downtown of my city, it is 5km from airport, but about 500 feet below the ground level of this airport.
So in this example, at 5km from the airport, if I fly to max altitude in country (300 feet), according to regulations I am "too close", to the airpot.
In reality it is still 200 feet BELOW the GROUND level of the runway!
Also this area is encompassed by hills, so for a plane to be near my drone, already means the plane is in trouble!
To me, it is acceptable to follow:
- Not over people (obviously)
- Not over "traffic" not necessarily roads:
- If there is a road, and no sign of traffic in either direction from the sky view, and i make sure I am high up, then as far as I am concerned it is perfectly ok to fly across this road, as the point of this rule is to not be in a position for drone to drop in traffic or distract drivers.
- Over private property to a point.
- Flying over say houses in a neighborhood is not as illegal as you may think! - The exact allowable height still seems gray, but technically what you need to avoid, is having a camera perspective on someones property, which could allow you to identify unique people or objects, which otherwise could not be identifyable from a conventional vantage point. The actual act of flying over the house is not what is bad.
- Back in the day a homeowner owned from "Heaven to Hell", meaning all the ground beneath the property, and all the sky above to infinity. All this changed when the aviation industry happened, so it is not considered private property to fly over a house/neighborhood anymore, and infact if was, FAA would need permission from everyone to fly anywhere, which is why this was changed. - So if you fly low over the house and can see in your neighbours window, obviously bad. If you are 300-400 feet high and flying over (say to get to your destination) this is actually ok for FAA!
