H265 playback issues
2721 17 2017-2-26
Burlingtonfilms
Flight distance : 108550 ft
Hi,
Has anyone been able to playback the h265 video files on their computer?  I'm having trouble getting them to playback on the latest Premiere CC and VLC.  Any tips?
Thanks.
2017-2-26
fanse186c04e
Flight distance : 26170253 ft
Mac or PC?
2017-2-26
edmoore
Flight distance : 598150 ft
I struggled on Mac... eventually just transcoded them to h.264.
Reading around it seems h.264 is hardware accelerated on almost all computers now whereas h.265 is pretty bleeding edge.
2017-2-26
Burlingtonfilms
fanse186c04e Posted at 2017-2-26 13:20
Mac or PC?
PC.  Not sure why it won't playback.
2017-2-26
Mark847
Flight distance : 745374 ft
Bump.. same here!  Just tried playing footage back on my Macbook (which I actually run windows on) and it's very jerky.. like it just can't handle it.  So basically pretty useless from what I can see unless maybe you hav a brand new pc/video card. ?
2017-2-27
Mike-the-cat
Flight distance : 22488593 ft
Singapore
Wait till high performance Intel Kaby Lake processors become common at the end of the year. These have h.265 decoding wired up in them. Decoding is very compute intensive.
2017-2-27
Puralist
How large is the file size? If you have a drop box account and can share, I can see if I can open or view the files. I have been working with h265 video files for the last couple of years.
2017-2-27
Mike-the-cat
Best solution: transcode to ProRes or h.264. Latter if you are editing. Former for viewing.
edited:sorry wrong way round. ProRes for editing...
2017-2-27
fanse186c04e
edmoore Posted at 2017-2-26 14:39
Mac, for now is not ready for H265, put it on H264 and you are good to go
2017-2-28
fanse186c04e
Burlingtonfilms Posted at 2017-2-26 20:22
Buy a mac and it will go realtime 4K in H264, latest mac and the version before ( laptop 15 inche ), no joke!!!
2017-2-28
Cobra44Magnum
Flight distance : 935135 ft
Mike-the-cat Posted at 2017-2-27 20:55
I believe that is reversed. ProRes is the preferred format to edit on a Mac. The downside is that the files are much bigger due to not being as compressed. H.264/H.265 are not optimal for editing but are fine for playback as long as you have the proper CODEC. A friend of mine recently bought a new Mac Pro and had stutters when editing 4K H.264 but smooth as silk when editing a ProRes file at the same resolution/FPS and higher bitrate.
2017-2-28
Cobra44Magnum
If you are going to edit them on a Mac you should transcode to ProRes. If you just want to view them then you can download a 3rd party video player that supports H.265 and skip the transcoding all together.
2017-2-28
Mike-the-cat
Singapore
Cobra44Magnum Posted at 2017-2-28 12:47
Thanks for pointing out my goof! I've edited my original post.
2017-2-28
Mike-the-cat
Singapore
Cobra44Magnum Posted at 2017-2-28 12:48
Yeah - but as we've said elsewhere, wait till the end of the year when hardware enabled decoding becomes more common
2017-2-28
ScooterC5
Flight distance : 435052 ft
If you're using a Mac and you shot your h.265 video in .mov format, simply rename the extension to .mp4.  Premiere Pro CC will then recognize it.  H.265 is not so user friendly in Premiere unless you have crazy specs... high end GPU, SSD, fast CPU and lots of memory... and with a Mac, specs aren't so crazy high unfortunately.  Shoot in ProRes 422 if you have the license and ability to do so and if you do, you'll need to correct the lens distortion in post since DJI didn't implement this correction in camera or prior to encoding.  Using a curvature setting of -7 should do the trick.
2017-2-28
fansfbd82212
Banned
Japan
2017-3-15
monica66
China
Is below article helpful? Good luck
http://hot-camcorder-device-vide ... miere-workflow.html
2017-3-28
Burlingtonfilms
Thanks for the replies.  So basically the H265 footage needs to be transcoded before editing in Premiere.  But I'm hopeful premiere will have an update to play the clips natively.
2017-6-3
