Geebax
mic75 Posted at 2017-3-2 16:10
"However I cannot see any reason why the SD card would affect the operation of the gimbal"
I'm not sure if you are doubting me but do you need a video of it.
I put the card in turn it on and it won't work, I turn it off take the sandisk out n put the factory one in, I then turn it on and hay presto it works. I have done this several times to confirm.
OK, that is a good card. Puzzling why it affects the gimbal, it should even be related. Have you been able to format the card in the aircraft? It may be there is something on the card that is causing the aircraft to stop during initialisation. If you cannot format the card in the aircraft, put it in a PC and format it in ExFAT and it might solve the problem.
