Has anyone had experience with balancing the props on the M600/ Pro? Every multicopter I have ever built and flown I balanced the props before installation. I have noticed quite a lot of vibration in at least two of the arms on my M600 Pro which suggests the props are not perfectly balanced. Since I cannot pass the balancer rod through the prop hub my magnetic balancer will not work. Has anybody solved this problem? Thanks
