cgmaxedgmail
Flight distance : 1999767 ft
USA. At night at about 3am, when wifi interference is low, I've seen friends mavic 2 pro's getting 19,000 feet or 3.6 miles or 5.8km horizontally one way at 45 mph sport mode.. There was very little wind. This required manual settings to find a frequency in the 2.4 ghz range with the lowest interference. To do this go into the HD menu on the go 4 app. Return home was cancelled a few times to get 19000 ft horizontally. Finally, when the battery was below 50%, the drone was returned home. This occured at about 19,000 feet , little to no wind. Height had to be increased above limit, due to trees and buildings. Some had modified go 4 apps. Not sure if this was the reason for extra distance. Anyway, even though some can get long distance, the battery is the true limiter when all said and done. On the "return home" speed was dropped to 26 mph to reduce drag/ air friction, allowing the drone to return home with 18% battery left. It used 60 percent battery going out at max speed 45mph and used only 35% battery returning home at moderate speed 26mph. Remember, No wind, thus air friction was high on the way out and reduced on the return home due to speed. |
38000 feet total out and back
