Are these video issues normal?
1058 7 2017-3-4
Watto
video
I got my Mavic around 2 weeks ago, and have noticed this thing in a some flights. Is that normal? What causes it? I am sorry if it's duplicate or known issue, but tried to search and didn't really know how to call that. Thanks a lot!
2017-3-4
Speed009
i get that sometimes when its super windy or when i halt from a fast brake. but if this happening on a nonwindy day seems like it would be a jello effect that I am afraid might have to resort sending it in for repair...I see you are flying at fort funston..good times.
2017-3-4
Wacker2611
Flight distance : 254075 ft
I had that exact same issue, sorry to say, but you'll need to send it back, it will only get worse. It's a hardware issue.
2017-3-4
Yhadar
Israel
You can check if the anti-vibration board is user the three hooks (one in the back and two in the front). If it is, I'm sorry to say it might be a hardware issue...
The hooks:
2017-3-4
Watto
Yhadar Posted at 2017-3-4 13:31
The hooks:
Sorry, I didn't understand
"You can check if the anti-vibration board is user the three hooks"
How should I check that? Thank you very much!
2017-3-4
Yhadar
Israel
Sometimes the anti-vibration board is over the tree hooks like this:
https://youtu.be/hnXekYjEJA8
2017-3-4
Jenee 2
Flight distance : 7852129 ft
You can check the gimbal as explained in this video:
If your gimbal is installed correctly then that isn't the problem and you will probably need to get it repaired as it will get worse. I had a similar issue.
2017-3-4
Please follow below video tutorial to check your gimbal first.
Besides, did you update the firmware to latest version?
2017-3-6
