Mavic battery drains without use
2552 8 2017-3-5
TobH
Austria
With 2 weeks of non-usage, the battery will dro from 100 to around 60 percent. Is that normal? And at what percentage should i leave them if i wont use them for some time?
2017-3-5
Aaticri
Flight distance : 213022 ft
That's normal as the batteries are programmed to auto discharge to prevent damage if being stored for a while
2017-3-5
Aaticri
If you look in the settings you can change the time from the default 10days
2017-3-5
AACY
Flight distance : 518012 ft
Any LIPO Battery should be keep balanced at 3.80Volts per cell for storage purposes. at that voltage the chemistry remains fairly stable and the degradation of the battery takes longer. Always remember to exercise the batteries charging them up and flying until you reach about 3.60Volt per cell.
2017-3-5
Nees
Flight distance : 80991 ft
Belgium
Please read the manual...
2017-3-5
AG0N-Gary
Flight distance : 700846 ft
Another one!!!  PLEASE READ THE MANUAL.
2017-3-5
TobH
Austria
AACY: Thanks for your answer!
To the other two: You must be fun at parties.
2017-3-5
Here is a video tutorial of battery maintenance for your reference:
2017-3-5
AACY
TobH Posted at 2017-3-5 15:19
No Problem! ;)
2017-3-5
