Ex Machina
Flight distance : 1806362 ft
From what I've been reading, problems appear to be when the Mavic unexpectedly switches from GPS to ATTI mode and people aren't prepared or are unable to control the AC. Unfortunately, there's no way to manually set ATTI mode, and the forum mods feel it's unlikely that there ever will be. Another piece of advice I've read is when inside, make sure to set your Max and RTH height to below-ceiling values and the Remote Controller Signal Loss setting to hover instead of RTH. Object avoidance may need to be turned off, and keep in mind VPS needs good light and a contrasty/patterned floor in order for it to do its job in helping keep the Mavic stable. That's all I can remember gleaning from forum posts.
It's may be safest to fly inside only when you are certain there's no chance of a GPS signal getting in, but perhaps others have found it doable; hopefully they'll weigh in. |
