Camera face towards left instead of facing center.
12Next >
34791 70 2017-3-6
fans04eda3a1
Camera face towards left instead of facing center and I have tried all gimbal calibration, Cold IMU calibration on a flat surface but nothing seem to work. I am dissapointed that my first drone is unable to navigate straight. It is highly impossible for me to shoot in narrow spaces. Also I do get horizon tilt when i yaw as well as at times during going straight as well.Please help.
2017-3-6
Cetacean
Flight distance : 2528264 ft
Aloha fans04,
     Are you flying in windy conditions?  Is you gimbal set to follow or FPV?  As an alternative, have you changed the order in which you are calibrating your gimbal and IMU?
Aloha and Drone On!
2017-3-7
DJI Natalia
Flight distance : 318 ft
This issue may occur if the gimbal is skewed due to shaking in transportation, and the rubber gimbal ring moves toward one side. To fix this issue, manually rotate the gimbal in the opposite direction of the tilt until it reaches its limit. Do this several times, and the gimbal should be centered.
2017-3-7
umatillagarry
DJI Natalia
Can you be more specific about how to do this? Is P4 powered up or not? Do you actually force gimbal to yaw side to side by physically grabbing and turning the camera all the way to the left and then all the way to the right? My camera is tilted to the right slightly maybe 5 degrees or so instead of pointing straight ahead. Thanks for you help.
2017-3-8
fans2f49b364
Uzbekistan
DJI Natalia Posted at 2017-3-7 02:02
Natalia when drone is off or on??
2017-3-8
fans2f49b364
Uzbekistan
can you give more information how to do it??
2017-3-8
fans04eda3a1
Cetacean Posted at 2017-3-7 01:30
Aloha fans04,
Hi.. Is there a specific way I should follow? also which is better FPV?
2017-3-8
Cetacean
fans04eda3a1 Posted at 2017-3-8 17:00
Aloha fans04,
     FPV will tilt your horizon when the wind blows hard or you bank hard.  Follow will level your horizon the best it can under all conditions.
     The calibration for IMU and gimbal have a logical and intuitive sequence but my bird is not intuitive or logical.  You would think to calibrate the IMU first and then follow with the  gimbal, but that leaves my gimbal way out of wack.  If I calibrate my gimbal first and follow with the IMU calibration, everything ends up level.  Go figgah!
     Hope this helps!
Aloha and Drone On!
2017-3-8
fans04eda3a1
Cetacean Posted at 2017-3-8 19:28
Aloha fans04,
Thanks buddy for your valuable inputs.. I shall try that Cal especially. I think I have it at FPV. I will change it to follow.
2017-3-8
DJI Natalia
umatillagarry Posted at 2017-3-8 09:32
DJI Natalia
Please power it off , then hold gimbal by your hand and rotate it to the left until it reaches its limit for several time since your camera is tilted to the right slightly.
Then please calibrate gimbal with the drone sitting on it's back, so the camera is pointing to the sky directly (assume the direction that the normal-functioning-camera is pointing to as front).
2017-3-9
Cetacean
DJI Natalia Posted at 2017-3-9 00:23
Aloha Natalia,
     This is interesting.  Will this technique work on all the newer Phantoms (P3A, P3P, P4, P4 Pro) or just the P4?
Aloha and Drone On!
2017-3-9
fans2f49b364
Uzbekistan
thank you for your help
it works perfect now
2017-3-9
fans04eda3a1
Thanks Natalia. I will give this a shot.
2017-3-9
fans04eda3a1
Hi Natalia, This issue is resolved now. Thanks for the support. But Horizon tilt seems to persist occasionally. Is there any suggestion for it...
2017-3-9
fans04eda3a1
2017-3-9
DJI Natalia
fans04eda3a1 Posted at 2017-3-9 13:54
Glad to hear it's solved.
For the horizon tilt issue, please calibrate the IMU in a very level surface firstly, then calibrate gimbal or adjust the Roll, then check the performance again.
2017-3-11
umatillagarry
I'm confused by this part... Then please calibrate gimbal with the drone sitting on it's back, so the camera is pointing to the sky directly (assume the direction that the normal-functioning-camera is pointing to as front).
What do you mean by "drone sitting on it's back" ? Do you mean drone is sitting on all 4 of it's motors ? What did you mean by "assume the direction that the normal-functioning-camera is pointing to as front).
Please clarify this for me... sorry for being so dense Thank you
2017-3-21
Grizz 1
Flight distance : 120066 ft
I think she means upside down from how you would normally do it.
2017-3-21
Punchbuggy
Flight distance : 483166 ft
Grizz 1 Posted at 2017-3-21 08:10
Natalia referred to the camera looking at the sky. I assume that she means that you sit the craft at 90 degrees on it's rear motor arms. But then I'm yet to try this to see if it calibrates OK that way...
2017-3-21
DJI-Jamie
Flight distance : 112405 ft
Punchbuggy Posted at 2017-3-21 15:05
Your interpretation would be correct.
2017-3-21
DJI Natalia
umatillagarry Posted at 2017-3-21 07:10
Sorry I did not make myself understood.
As Punchbuggy mentioned at 19#, please do it like that.
@Punchbuggy, thank you.
2017-3-22
umatillagarry
DJI-Jamie Posted at 2017-3-21 15:22
But how would you have it on it's rear motor mounts and have it level like it wants for a gimbal calibration? Would you somehow prop it up to make it as level as possible while having it sit on it's rear motors?
2017-3-22
Punchbuggy
umatillagarry Posted at 2017-3-22 12:40
While waiting on DJI's advice, I'd suggest that doing a gimbal calibration using this technique is purely just to get the camera properly centred (left-right axis) on the gimbal again. Remember that up to here you've basically forced the rubber ring to re-seat itself back into correct positioning.
My guess is that, once you've got the ring re-seated correctly and the camera is now centred on that axis following calibration at the 90 degree angle, you put the craft back down 100% flat (as per normal) and do a normal gimbal calibration to get the other motors calibrated properly (the gimbal uses 3 in total). Happy to be corrected here though - I'm just using logic.
2017-3-22
umatillagarry
Natalia a picture is worth a 1000 words.. could you please give us a picture of a P4 sitting in the configuration you mean for the gimbal cal to take place in??
Thanks in advance.
2017-3-23
DJI Natalia
umatillagarry Posted at 2017-3-23 13:11
Here is  a picture for your reference:
2017-3-27
umatillagarry
DJI Natalia Posted at 2017-3-27 23:35
Thank you for the clarification.
2017-3-28
DJI Natalia
umatillagarry Posted at 2017-3-28 13:08
You are welcome, hope that helps.
2017-3-29
XXTechMoXX
Flight distance : 403530 ft
That worked for me! Thank you so much!
2017-4-23
DJI Natalia
XXTechMoXX Posted at 2017-4-23 09:54
Great, glad to hear it helps.
2017-4-23
omegas
Flight distance : 23757 ft
Russia
Hello, i think i have the same issue. I'am calibrate all parts on precisely leveled surface, but my cam looked some left. And i don't understand how many power of my hands i need to use for this procedure... Help me, may be someone have video?
2017-4-23
MDMAN
Flight distance : 115046 ft
I have the same issue... But I don't know how I can fix it. I make the same procedure like @XXTechMoXX but my Gimbal is not in the Center. It have 5 Degrees left.
Also like @omegas ...
An Video is a good Idea. Can someone make an Video for us?
Thanks a lot...
2017-4-24
fans88ccc2f5
Flight distance : 801099 ft
Had the same problem with mine. Followed the above steps and all seems to be OK, but haven't flown since this 'fix'.
I would like to know if this is something that I should expect to have to do frequently? The aircraft is new and has done around 20 flights - I didn't encounter this gimbal issue until after a few flights, so is it likely to happen again?
2017-4-26
Brian Liem
Flight distance : 882113 ft
Natalia, in theory the idea works. After flying and landing softly ;) the gimbal was back to pointing to the left 5-10 degrees. I'm a drone tech so far as hardware is concerned, so I have no fear of removing the gimbal completely. Is there is a permanent "fix" or adjustment that can be done internally? The only reason I havent done this on my own is this particular drone is fairly new and still under warranty.  Any thoughts?
2017-4-26
Mike_97
Flight distance : 210715 ft
My camera also points a few degrees left of center. Not a problem when I'm flying at altitude, but I noticed how severe it was flying indoors, trying to fly straight down the hall and having to compensate with a little left input on the right stick (slew or crab left).
Could we get an additional software gimbal calibration feature, just like the gimbal-tilt adjustment, but make this a gimbal-yaw adjustment?
2017-4-26
Mobilcams
Flight distance : 2907674 ft
Natalia!! THANK YOU!! I have been plagued by this issue for a while and wondered what was wrong with my unit.. It was repaired and sent back to me with a separate issue regarding the gimbal.. Since I have gotten it back I have no longer had the original issue at hand but have noticed it pointing to the left every since..
I did the calibration you suggested today and everything is dead square on.. It was a little precarious balancing the drone on a level surface as shown but I watched the calibration and noticed a FEW MORE CALIBRATION MOVEMENTS not normally associated with the gimbal calibration.. Lo and behold my camera points dead on straight now!!! Took her for a few flights and still straight!! Thank you!!!
2017-4-27
DJI Natalia
Mobilcams Posted at 2017-4-27 16:33
Pretty nice, glad to hear it performs fine after you tried to calibrate in that way.
Enjoy and hope you have a great time on flying the drone!
2017-4-29
fans3e584ba0
I've just done this and it has worked! Hurray
2017-4-29
DJI Natalia
fans3e584ba0 Posted at 2017-4-29 00:53
That's great!
2017-4-29
Paulo Paulino
Flight distance : 2774265 ft
Portugal
This information comes in very handy, thanks.
2017-4-29
Brian Liem
Natalia, Please see attached photos
P4Pro
P4Pro
P4Pro
P4Pro
2017-5-4
12Next >
