6 FPS video with Filmic pro
1825 2 2017-3-7
GZP
Latvia
Very strange. Settings set on 30 FPS, 4k. But got only 6 FPS video (this is written in the file details and also Premier Pro shows 6,23 FPS).  How it is possible to get video with 6 FPS? Also with this program screen blinks regularly (used with Osmo mobile, Android).
Checked other videos, 6 fps, 17 fps. That program change frame rate by itself.
Those who have experience with Filmic pro usage, does it work correctly?
2017-3-7
MarekO
check your settings again, there are two settings for playback and record. Save your settings ( for example 60 fps record/60 fps playback) to a preset and it will automatically load on every startup.
2017-3-10
yelenavik
MarekO Posted at 2017-3-10 16:34
usually smartphones recording variable frame,depense how fast is motion,so 6fps is min, 29.97max ,same 59.97fps is max if in setting 1080x60fps
2017-3-10
