GPS information in JPG and DNG properties?
6692 2 2017-3-8
Andy LIS
Flight distance : 3358875 ft
Hi folks,
Can anyone tell me if they are able to see GPS data (position, altitiude etc) in the file properties of an image taken on a Mavic Pro?  When I go the file details (right click, properties and bring up the details tab on my windows 10 machine) I get basic stuff like image dimensions, width, height resolution, but no info on the camera type, or GPS info.  That is both on DNG files and JPG files taken with my Mavic.
If I look at an image taken on my old Phantom 4, I can see info like the camera type, and GPS longitude and latitude etc.
Is there another way to view this information that I should be using?  Or a particular way to import pictures from the Mavic?
Cheers
Andy
2017-3-8
Ex Machina
Flight distance : 1806362 ft
I see them in Adobe Lightroom, in both DNG and JPG, see screengrab:
2017-3-8
Daroga
Flight distance : 3517287 ft
Hi Andy LIS,
    The exif data is there, it's just that Windows is somewhat random in it's native ability to extract the information. On my Win 10 machines JPGs usually include the information, but Windows rarely finds the info within DNGs.
   The best route to see this data is to use a dedicated EXIF extraction tool. Phil Harvey at Queens University in Kingston, Ontario, Canada has written one such tool called ExifTool. You can jump to the download page by clicking on this link....
His ExifTool is a command line/termial shell type PERL application. But the stand-alone Windows executable does not require Perl and it runs on all versions of Windows.  Just download and un-zip the archive then double-click on "exiftool(-k).exe" to read the application documentation, drag-and-drop files and folders to view meta information. You can also rename the "exiftool(-k).exe" by changing the various commandline switches to produce the exact output you need. I renamed my executable to "exiftool(-a -u -g1 -w txt).exe". I simply drag the photo file  onto the ExifTool icon and it produces an output txt file with the same name as the photo...
Forgive the length of this sample output of DJI_0017.DNG (notice the warning on the second line -> probably why Windows doesn't extract the info correctly):
---- ExifTool ----
ExifTool Version Number         : 10.45
Warning                         : [minor] Possibly incorrect maker notes offsets (fix by 13312?)
---- System ----
File Name                       : DJI_0017.DNG
Directory                       : C:/Users/Daroga/Desktop/100MEDIA
File Size                       : 23 MB
File Modification Date/Time     : 2016:12:22 08:41:52-05:00
File Access Date/Time           : 2017:03:08 11:15:11-05:00
File Creation Date/Time         : 2017:03:08 11:15:11-05:00
File Permissions                : rw-rw-rw-
---- File ----
File Type                       : DNG
File Type Extension             : dng
MIME Type                       : image/x-adobe-dng
Exif Byte Order                 : Little-endian (Intel, II)
---- IFD0 ----
Subfile Type                    : Reduced-resolution image
Image Width                     : 160
Image Height                    : 120
Bits Per Sample                 : 8 8 8
Compression                     : JPEG
Photometric Interpretation      : YCbCr
Make                            : DJI
Camera Model Name               : FC220
Preview Image Start             : 26066
Orientation                     : Horizontal (normal)
Samples Per Pixel               : 3
Preview Image Length            : 7210
Software                        : v01.05.5546
Modify Date                     : 2016:12:22 08:41:51
XP Comment                      : 0.9.141
XP Keywords                     : N
DNG Version                     : 1.4.0.0
DNG Backward Version            : 1.3.0.0
Unique Camera Model             : FC220
Color Matrix 1                  : 1.3488 -0.8849 0.0929 -0.1484 0.7881 0.4303 -0.0302 0.0979 0.5113
Color Matrix 2                  : 0.876 -0.2517 -0.0607 -0.2745 1.0465 0.2644 -0.0943 0.1792 0.5458
Analog Balance                  : 1 1 1
As Shot Neutral                 : 0.439296 1 0.750733
Baseline Exposure               : 0
Baseline Noise                  : 1
Baseline Sharpness              : 1
Linear Response Limit           : 1
Camera Serial Number            : 2014031100
DNG Lens Info                   : 26.3mm f/2.2
Shadow Scale                    : 1
DNG Private Data                : (Binary data 256 bytes, use -b option to extract)
Calibration Illuminant 1        : Standard Light A
Calibration Illuminant 2        : D65
Profile Hue Sat Map Dims        : 6 6 3
Profile Hue Sat Map Data 1      : (Binary data 3722 bytes, use -b option to extract)
Profile Hue Sat Map Data 2      : (Binary data 3738 bytes, use -b option to extract)
Profile Embed Policy            : Allow Copying
Original Default Final Size     : 0 0
Original Best Quality Size      : 0 0
Original Default Crop Size      : undef undef
Preview Image                   : (Binary data 7210 bytes, use -b option to extract)
---- SubIFD ----
Subfile Type                    : Full-resolution Image
Image Width                     : 4000
Image Height                    : 3000
Bits Per Sample                 : 16
Compression                     : Uncompressed
Photometric Interpretation      : Color Filter Array
Strip Offsets                   : 295925
Samples Per Pixel               : 1
Rows Per Strip                  : 3000
Strip Byte Counts               : 24000000
Planar Configuration            : Chunky
CFA Repeat Pattern Dim          : 2 2
CFA Pattern 2                   : 0 1 1 2
CFA Plane Color                 : Red,Green,Blue
CFA Layout                      : Rectangular
Black Level Repeat Dim          : 2 2
Black Level                     : 800 800 800 800
White Level                     : 16383
Default Scale                   : 1 1
Default Crop Origin             : 4 4
Default Crop Size               : 3992 2992
Bayer Green Split               : 0
Anti Alias Strength             : 1
Best Quality Scale              : 1
Active Area                     : 0 0 3000 4000
Opcode List 1                   : (Binary data 12088 bytes, use -b option to extract)
Opcode List 3                   : (Binary data 76 bytes, use -b option to extract)
Default User Crop               : 0 0 1 1
---- SubIFD1 ----
Image Width                     : 960
Image Height                    : 720
Compression                     : JPEG
Preview Image Start             : 33276
Rows Per Strip                  : 720
Preview Image Length            : 262649
Y Cb Cr Coefficients            : 0.299 0.587 0.114
Y Cb Cr Sub Sampling            : YCbCr4:2:0 (2 2)
Y Cb Cr Positioning             : Co-sited
Reference Black White           : 0 255 128 255 128 255
Preview Image                   : (Binary data 262649 bytes, use -b option to extract)
---- XMP-rdf ----
About                           : DJI Meta Data
---- XMP-xmp ----
Modify Date                     : 2014:10:13
Create Date                     : 2014:10:13
---- XMP-tiff ----
Make                            : DJI
---- XMP-dc ----
Format                          : image/dng
---- XMP-drone-dji ----
Absolute Altitude               : +1592.60
Relative Altitude               : +22.50
Gimbal Roll Degree              : +0.00
Gimbal Yaw Degree               : +39.50
Gimbal Pitch Degree             : -6.10
Flight Roll Degree              : +0.00
Flight Yaw Degree               : +39.50
Flight Pitch Degree             : -0.60
---- XMP-crs ----
Version                         : 7.0
Has Settings                    : False
Has Crop                        : False
Already Applied                 : False
---- ExifIFD ----
Exposure Time                   : 1/60
F Number                        : 2.2
Exposure Program                : Unknown (58655)
ISO                             : 101
Exif Version                    : 0230
Date/Time Original              : 2016:12:22 08:41:51
Create Date                     : 2016:12:22 08:41:51
Shutter Speed Value             : 1/60
Aperture Value                  : 2.2
Exposure Compensation           : 0
Max Aperture Value              : 2.2
Subject Distance                : 0 m
Metering Mode                   : Center-weighted average
Light Source                    : Unknown
Flash                           : No flash function
Focal Length                    : 4.7 mm
File Source                     : Digital Camera
Scene Type                      : Directly photographed
Custom Rendered                 : Normal
Exposure Mode                   : Auto
White Balance                   : Auto
Digital Zoom Ratio              : 0
Focal Length In 35mm Format     : 26 mm
Scene Capture Type              : Standard
Gain Control                    : None
Contrast                        : Normal
Saturation                      : Normal
Sharpness                       : Normal
Subject Distance Range          : Unknown
---- DJI ----
Make                            : DJI
DJI 0x0002                      : 1 2 0 0
Speed X                         : +0.00
Speed Y                         : +0.00
Speed Z                         : +0.00
Pitch                           : -0.40
Yaw                             : +39.50
Roll                            : +0.00
Camera Pitch                    : -6.10
Camera Yaw                      : +39.50
Camera Roll                     : +0.00
DJI 0x0015                      : T.
DJI 0x0016                      : J..
---- GPS ----
GPS Version ID: 2.3.0.0
GPS Latitude Ref: North
GPS Latitude: 46 deg 1' 16.29"
GPS Longitude Ref: East
GPS Longitude: 7 deg 45' 6.93"
GPS Altitude Ref: Above Sea Level
GPS Altitude: 22.4 m
---- Composite ----
Aperture                        : 2.2
CFA Pattern                     : [Red,Green][Green,Blue]
GPS Altitude                    : 22.4 m Above Sea Level
GPS Latitude: 46 deg 1' 16.29" N
GPS Longitude: 7 deg 45' 6.93" E
GPS Position: 46 deg 1' 16.29" N, 7 deg 45' 6.93" E
Image Size                      : 4000x3000
Megapixels                      : 12.0
Scale Factor To 35 mm Equivalent: 5.5
Shutter Speed                   : 1/60
Circle Of Confusion             : 0.005 mm
Field Of View                   : 69.4 deg
Focal Length                    : 4.7 mm (35 mm equivalent: 26.0 mm)
Hyperfocal Distance             : 1.85
Light Value                     : 8.2
2017-3-8
