Gimbal is looking right a little bit
503 3 2017-3-8
fans2f49b364
Uzbekistan
i did imu calibrations and gimbal calibrations it could not help
2017-3-8
fans2f49b364
Uzbekistan
it is not centering
2017-3-8
Punchbuggy
Flight distance : 483166 ft
Hi. Have a look at this thread, and wait for Natalia's answer for whether the craft should be turned on or off (my bet is off, by the way, as if the craft is on, the gimbal will fight against you when you're trying to do it).
http://forum.dji.com/thread-87837-1-1.html
2017-3-8
DJI Natalia
Flight distance : 318 ft
Punchbuggy Posted at 2017-3-8 14:31
Correct, the drone should be off when rotating it.
After doing that, please calibrate gimbal with the drone sitting on it's back, so the camera is pointing to the sky directly (assume the direction that the normal-functioning-camera is pointing to as front).
2017-3-9
