My 3 phantom fell out of sky
12Next >
5532 59 2017-3-8
fans2ef469d5
I have 59 hours of flight not one issue....downloaded new update on dji go app...and second flight fell out  of the sky at 260ft... No wind, sunny, beautuful and was not touching stick.  Just fell out of the sky... Anyone else have this issue?  Please advise.
2017-3-8
Cabansail
Flight distance : 136686 ft
Dou you have the Flight Logs available?
2017-3-8
DJI-Jamie
Flight distance : 112405 ft
I'm sorry to hear. Have you already started a repair service with the NA Support Center?
2017-3-8
blackcrusader
Flight distance : 689774 ft
Taiwan
I believe if everyone was having this issue we would have heard about it.
Sounds like you had a power failure or maybe a large insect or bird hit your props.
It would be remiss if also your battery wasn't seated all the way in but I assumed it is.
Hopefully your flight records will help.
2017-3-8
fans2ef469d5
So if the battery wasn't seated what would the support center say would it be my fault or they would repair it at no cost
2017-3-9
fans2ef469d5
And yes I will give u the flight logs if I can fined out how to
2017-3-9
Labroides
Flight distance : 9991457 ft
fans2ef469d5 Posted at 2017-3-9 05:58
Go to http://www.phantomhelp.com/LogViewer/Upload/
Follow the instructions to upload your flight record.
Come back and post a link to the report it provides .
2017-3-9
jobocs82
Did you try to correct it with the sticks?
2017-3-9
blackcrusader
Taiwan
fans2ef469d5 Posted at 2017-3-9 05:57
2 days ago I went to a friends place to film his farm and surrounding areas.   I have 3 batteries so second battery I let him try my drone.  I also showed him how you can insert a battery and think they are fine but if not clicked in properly can be pulled out.  So I always click them in then try to pull out to ensure seated correctly.  He was really surprised how easy the drone was to use.  Then I downloaded the file to open in google earth so can show the latitude and longitude and the flight path.
If battery is not inserted correctly that is pilot error.
2017-3-9
DJI-Jamie
Like blackcrusader mentioned, not properly inserting the battery wouldn't be covered under warranty if that is the case. To clarify, however, are you in the process of getting your flight records reviewed by Support?
2017-3-9
Geebax
Why are we focussing on a battery falling out? The OP has not said anything to indicate that this happened to him. At this time, nothing is known, and until flight records are viewed, not much more can be deduced.
2017-3-10
~G~
A month or so ago, I flew my drone.  Everything started up ok, battery level was at 80%, calibration was normal and I had a good GPS lock.  I took it up to around 175 feet and flew out about 500 feet when all of a sudden I got a message saying critical battery, and the drone was landing.  I was unable to cancel the landing but I did have directional control.  I was lucky and got the drone back to where I was flying from and landed.  Rule is, always charge your battery fully before flight.  I had charged it a week prior and didn't think there would be any issue.  I have had no issues since but make sure I top off the batteries before each flight.
2017-3-10
DJI-Ken
Flight distance : 1515312 ft
If you sync your flight records and provide the emailed used to with the GO app I will review the flight to see if I see anything unusual.
Here's the link to contact support, and sorry for your crash.
http://www.dji.com/support
2017-3-10
RedHotPoker
Flight distance : 165105 ft
Geebax Posted at 2017-3-10 00:08
It's shameful. They seem to prefer to look for an easy way around the obvious... Instead of staying true to the pilot.
It's simpler to Blame the operator. Instead of looking deeper into the real reason for these failures.
I'm keen to see the flight LOG first, and try to establish a real error, not guessing, and pointing fingers.
I will always be sure my flight packs are seated properly, before flying. Knowing what we see above, as an easy out....
RedHotPoker
2017-3-10
fans2ef469d5
I can't seem to find your how to give you guys the flight logs
2017-3-14
blackcrusader
Taiwan
fans2ef469d5 Posted at 2017-3-14 20:19
Pretty simple really.  You could register with healthydrones and upload your logs as they are on your smartphone or tab.  From there you go to the date of the flight and download the information file.
You can also download the CSV file as well and email them to DJI support.
2017-3-14
DJI-Jamie
To sync the flight records in the Go app, you would select the cloud icon that's in the top right corner of the Flight Record section.
2017-3-14
blackcrusader
Taiwan
DJI-Jamie Posted at 2017-3-14 21:20
To do that make sure you are connected to your home wifi as well.
Jamie just as a point of interest if I did that and wanted to let you access those records uploaded on my DJI App would you just need my Drones username?
Is that enough or would you need other information as well?
2017-3-14
DJI-Jamie
blackcrusader Posted at 2017-3-14 23:32
I would need the email you used to activate the drone and the date that needed to be looked up.
2017-3-15
blackcrusader
Taiwan
DJI-Jamie Posted at 2017-3-15 07:36
OK.  I am not having issues as you know just wanted to make sure how the procedure works.
2017-3-15
fans2ef469d5
Yes that is good thanks I'll get those to u as soon as possible so u guys man look at them
2017-3-15
fans2ef469d5
OK so I have downloaded the flight logs to healthy drones.com and from there how do I get them to the forums
2017-3-15
G_Sig
Flight distance : 9109311 ft
Iceland
fans2ef469d5 Posted at 2017-3-15 09:23
Green button in upper right corner.
2017-3-15
fans2ef469d5
http://healthydrones.com/main?share=hIzHwA
is that what I am suposed to send
2017-3-15
DJI-Jamie
fans2ef469d5 Posted at 2017-3-15 11:49
Just to clarify, have you contacted Support regarding your flight records as well?
2017-3-15
fans2ef469d5
Yes I have but I want to know what people say on the forums so I can know what's coming does that make sense
2017-3-16
fans3d7e60a1
Flight distance : 1555344 ft
jobocs82 Posted at 2017-3-9 15:31
He had a complete power loss because the battery wasn't seated
2017-3-16
fans2ef469d5
Is that what happen?? Or are u just saying that is what u think happen??
2017-3-16
blackcrusader
Taiwan
fans3d7e60a1 Posted at 2017-3-16 06:16
I cannot see that from the link provided what I do see it says 86% battery at landing.
You don't land when in the air that's for sure.
Perhaps if the OP can download the original file from healthy drones and upload it to http://www.phantomhelp.com/LogViewer/Upload/
Flight timeAltitudeHome DistanceTypeNotification
A00m 00s0.0 ft0 ftModeMode changed to GPS_Atti
B00m 00s0.0 ft0 ftTipHome Point Recorded
C00m 02s-1.3 ft0 ftModeMode changed to AutoTakeoff
D00m 02s-1.3 ft0 ftWarningReturn-to-Home Altitude:131FT
E00m 02s-1.3 ft0 ftTipTaking off
F00m 08s7.2 ft0 ftModeMode changed to GPS_Atti
G01m 45s241.5 ft480 ftData LossDownlink data connection lost for 1 seconds
2017-3-16
fans2ef469d5
To down load the original file to http://www.phantomhelp.com/logviewer/upload/
Do I need to go on the computer to do that??
2017-3-16
blackcrusader
Taiwan
fans2ef469d5 Posted at 2017-3-16 14:16
Yes download it to your computer from healthydrones.com
Then open the Phantomhelp page and click on the file then upload it using upload log. So you need internet to upload.
Once it's uploaded copy the URL and paste it here.  Will look like this...
http://www.phantomhelp.com/LogViewer/HDFKE6N6CP8ADW7XYLWO/
2017-3-16
Maxxpsoft
Flight distance : 380594 ft
wow look at the battery cell deviation on the healthydrone log
Phantomhelp will show things better
2017-3-16
blackcrusader
Taiwan
Maxxpsoft Posted at 2017-3-16 22:39
Yup it seems to be the battery is having issues.
POWER DEVIATIONS
POWER DEVIATIONS
2017-3-17
fans2ef469d5
Is that what it was for sure or is it a possibility??? Do I need to do anything else???
2017-3-17
JackA
Flight distance : 32057 ft
Both cell #3 and #4 are out of ordinary tolerance fir Li.
2017-3-17
fans2ef469d5
So it that a me issue or a Dji issue
2017-3-17
Cessna172
Just remember battery voltage does not keep your Phantom in the sky, CURRENT does.   Voltage is simply a measure of potential.   A battery can say 100%, yet have only enough capacity to lift the Phantom to height, then lose all ability to keep it there.
No Phantoms that I am aware of can tell you the batteries current capacity.   Only voltage.    Therefore you must have some knowledge of these things because voltage alone is not enough information.
Yes, I'm telling you that you can never completely trust the voltage indication or "battery percentage" fully.
You have to "know" your battery and occasionally TEST the real capacity yourself.
This is the reason it is never a good idea to make multiple flights on a single charge or fly with a battery that has been shelved for some time....or a partially charged battery.
2017-3-17
DJI-Jamie
fans2ef469d5 Posted at 2017-3-17 13:57
It depends on whether or not the deviation was caused by prolonged aggressive flying or if it was just sporatic. The latter tend to be covered under warranty if the battery is within its warranty period. If you flew knowing it was a damaged battery (per warning messages etc.) could void the warranty as well.
2017-3-17
fans2ef469d5
So if voltage is not the problem can u go look on the like I put out and find out what the real reason this all happe...
I know it was not aggressive flying because I was just sitting still looking at somthing so we can eliminate aggressively flying
2017-3-17
blackcrusader
Taiwan
fans2ef469d5 Posted at 2017-3-17 17:34
OK Please also read this thread. You can also use healthydrones to see more information about your battery condition, number of flights, number of charges, cell deviations etc.
The flight I got my critical message I was also hovering taking a video.  If DJI said hey BC you do push your flights to the limit I might need to agree. I do fly often to max height and far distances.  Not always its just depends on my location.   I did a near 13000' distance in a valley at a height of 400'.  So 26000' to get out and back and came back with 35% battery.
Very light wind and it was just a fun flight to test my Artek range.  Is this pushing the drone and the battery hard?
http://forum.dji.com/thread-89101-1-1.html
2017-3-17
12Next >
