CuaC
Flight distance : 369626 ft
rnrnrn Posted at 2017-3-9 10:35
Hi Cuac,
I was going through the regulations to double check and... nowhere have I found any info about this. From what I can see it's just guesswork - because all marking elements on aircraft parts have to be fire resistant. That's nice. That's why they also state that you need insurance. Nice. It also says that you need to register your aircraft to fly in German airspace or you need registration abroad and Erlaubnis to fly it. This last point is not raised by anyone. Guess why? Because you can't register your drone.
The new requirements are still not in place, but I guess will be soon. I don´t know where I read about the fire proof labels, but apparently that´s also the case in Spain (mandatory label, and fines of 4000 € given for non compliance) and as I´m Spanish expat and I go often to Spain I´ll try to do a labeling that matches both regulations at least. If in the end it´s not necessary for the label to be fireproof in Germany... well... no harm anyway.
On the insurance thing I do have the paragraph on the LuftVO:
Luftverkehrs-Zulassungs-Ordnung (LuftVZO)
§ 102 Vertragsinhalt
(1) Der Haftpflichtversicherungsvertrag für Drittschäden muss die sich aus dem Betrieb eines Luftfahrzeugs für den Halter ergebende Haftung decken.
(2) Die Mindesthöhe der Versicherungssumme bestimmt sich bei Luftfahrzeugen nach § 37 Abs. 1 des Luftverkehrsgesetzes.
(3) Für Drachen, Flugmodelle und nichtmotorgetriebene Luftsportgeräte ist Gruppenversicherung zulässig. |
