solentlife
Flight distance : 1087530 ft
Latvia
Those micro SD card slots are a real ba****d if you get card not quite right ... I have cameras and gear that the plastic surround is not close enough and you can slip the card into the case OVER THE TOP of the slot !!
I have others that you can literally force the card in wrong way ...
You have to be extra careful to make sure card is going into its slot properly.
My way to free a stuck card is carefully use a very small jewellers driver and 'pick' at the card ends literally prising up a tiny bit each end ... till it can be popped by the driver using the slight ridge along its top edge.
Nigel
