DJI Assistant 2 driver issues
12Next >
45602 74 2017-3-9
D'Arcy Marcell
I am a new Mavic owner and I am having trouble with the DJI assistant 2 software. My computer is running Windows 7 ultimate (64 bit). I am using DJI Assistant 2 version 1.1.0 My Mavic's firmware version is V01.03.0500 The issue I am having is when I try to go into the calibration it continually says to reboot my drone. when I checked the my device manager it seams as if I may be having driver issues. Under ports (com & lpt)  DJI USB Virtual Com (com 4) can't start  DJI USB Virtual Com (com 5) is operating properly and under libusb-win32 devices the vision (interface 3) driver says can't be verified by windows I am including a screen capture of the pertinent items any help would be much appreciated.
2017-3-9
Did you disable the antivirus software?
Please try to reinstall the DJI assistant. If convenient, please test with another computer.
2017-3-9
D'Arcy Marcell
DJI Mindy Posted at 2017-3-9 23:07
Did a reinstall (without antivirus) also on another computer main problem is that the new driver is not digitally signed so windows doesn't recognize it as valid.
2017-3-11
shnh25
This was posted by another user (Failed Icarus) Check on how to "Disable the Windows Digital Signature" for your OS and try installing it again. It worked for me (Windows 10 64b)
Follow these steps to resolve the issue:
1) Uninstall DJI Assistant 2
2) Disable the Windows Digital Signature Requirement
Note: Steps to do this can be found here: Spark Fun Guide https://learn.sparkfun.com/tutor ... cement-on-windows-8
3) Re-Install the DJI software
4) Calibrate per instructions
5) ...
6) Profit
2017-3-11
Please try with shnh25's advice to see if it helps.
Keep us posted.
2017-3-12
fans0bd879ef
Vietnam
Same here and I tried shnh25's advices but it's not working....
2017-3-23
bunny too
Flight distance : 13442 ft
fans0bd879ef Posted at 2017-3-23 07:56
Hold controll and click the restart button, you should pull up a window that allows you to disable driver signage.  Good Luck,
Regards,
-d.
2017-3-23
Lieta F4
Vietnam
bunny too Posted at 2017-3-23 08:03
Regards,
-d.
It is already turned off and still got the prob here...
2017-3-23
bunny too
Lieta F4 Posted at 2017-3-23 08:08
Take a look at this thread http://mavicpilots.com/threads/sensor-calibration.7997/
It tells you how to get the driver working mostly the video from average dad.
Regards,
-d
2017-3-23
Chiangcsr
Flight distance : 8081 ft
Singapore
Mavic Pro Driver Error For Dji Assistant Software And How To Get Around It http://mavicpro.yoursingaporeimporters.com/…/mavic-pro-dri…/
2017-3-31
YellowRaven
DJI Mindy Posted at 2017-3-12 22:34
Keep us posted.
Dear DJI support,
I would not like to turn off driver signature verification on Win10 due to security reasons. And I have no possibilities to connect my Naza to computer.
Why you for so long time (since 2015 according forums) still did not sight your drivers?
Thank you.
2017-5-26
randy.sauder
Flight distance : 872572 ft
If people are still having this issue (as I also did a couple months ago), the root cause is with Windows 7. Specifically that Windows 7 Update stops working for people that do not update their computers with Microsoft Update and when this happens, the updates required to allow DJI's drivers to work do not install.
Fixing the Windows Update service fixes this issue 100%.
It personally took me over 12 hours of trial and error and research  to discover this.  There is lots of info about this on the net and Microsoft is aware but Win 7 has been losing support for a long time.
Following "Option 1" in the below link will fix this issue with Assistant 2.
https://www.drivereasy.com/knowl ... for-updates-solved/
Once these steps are followed and the Win 7 Updates are installed on user's computers, DJI Assistant 2 will work as designed.
Thanks.
2017-5-26
hegrra
India
This is really irritating issue, I faced same issue now fixed with this guide.   https://www.howtoseeks.com/windows-update-stuck/ thanks for read.
2017-6-11
fans3b185f9a
hegrra Posted at 2017-6-11 04:14
So, I have this issue with the Phantom 4, and I really do not think that disabling driver signing is a solution.
I mean, this is a real official product, not a home made, half baked "hello world"-project.
It should be working out of the box with signed drivers.
Someone said that this was an issue with windows updates, sorry to say that this is not the case.
Signed drivers has nothing to do with windows update.
I hope you get this sorted out because using the firmware updates via the pad is not always logical nor practical.
Specially if I use the android version that keeps on crashing 8 times per 3 batteries.
Luckily I have an Ipad assigned just to this drone.
Best Regards
Charlie Candergart
2017-6-21
Bintryin
Flight distance : 164406 ft
randy.sauder Posted at 2017-5-26 18:57
Didn't  work for me sure my drivers are all up to date and $50.00 out of pocket but the usb is still not fixed
2017-6-21
randy.sauder
Bintryin Posted at 2017-6-21 13:18
If you are certain your windows is up-to-date, then: remove all 'usb' related drivers using Device Manager manually.  Then reinstall the DJI app.   Not sure about where your $50 bucks went to??
2017-6-21
Bintryin
randy.sauder Posted at 2017-6-21 22:06
$50.00 Australian if you have a look! for 1 year
2017-6-24
RCNJ
Flight distance : 114665 ft
I could get controller to be seen but not mavic, gave up in end and just used app
2017-6-24
mathe
India
Hi D'Arcy Marcell,
You are using laptop windows 7, 64bit operating system and have been driver problem. I was faced that problem few months back same like that then installed latest drivers. You will not get any software issues by install latest drivers like that graphic cards, Bluetooth, USB, WLAN. I have been using that drivers in my laptop didn’t get any problem my laptop.my better suggestion is If you want that drivers and once you can install.
2017-10-14
fans2dbea8ea
shnh25 Posted at 2017-3-11 16:52
That worked for me.  Thanks for the help.  How come this is necessary at all?  Shouldn't DJI supply drivers that pass driver signature checking?
2017-11-28
fans2dbea8ea
2017-11-28
djiuser_ux1ynlM
Pakistan
Hi, dear i liked it your post, you can so amazing post sharing
2018-1-10
djiuser_ux1ynlM
Pakistan
Great website Http://www.realapks.com
2018-1-10
djiuser_ux1ynlM
Pakistan
Hello, dear so amazing article sharing keep it up.
If you can download android mobile apps and games just follow this website WWW.REALAPKS.COM
2018-1-10
shakeelnago
Pakistan
Nice post. MG Liker
2018-1-30
shakeelnago
Pakistan
Thanks for sharing wonderful content.
Happy New Year 2019 Quotes
freestore
Mobile Drivers
Volcano Box
ApentalCalc
2018-1-30
ttait01
What worked for me is to navigate to the assistant program folder and install the drivers 'as administrator'.  But what I'd really like to know is why DJI Go 4 doesn't want to work on my Galaxy S2 Tablet without a restart? (but with a restart it works great)
2018-1-30
djiuser_sjKSq32ktgF5
Flight distance : 8041 ft
This works but only when you boot computer with driver signing disabled. A solution with Windows booted normally would be much preferred.
2018-2-8
shakeelnago
Pakistan
Nice one. AC Market
2018-4-8
danielsmm
Pakistan
From here you can Download firmware flash file frp tools and pc software.
2018-5-12
AREEBNINGA
Thank for sharing mate
happy new year 2019 quotes
2018-7-5
defic
India
Thanks for sharing pal.
happy new year wishes 2019
Short hairstyles for womens
2018-8-25
gnirtS
Flight distance : 5712575 ft
Its incredible that a company like DJI hasnt bothered with signed drivers for 3+ YEARS and your only way to use them is to make your computer insecure against the guidelines of all manufacturers and microsoft themselves.
Signing costs a bit of money.  A small amount.  Less than the cost of a drone.
Then again, this is the same company that left its web and other private keys publicly accessible on GitHub for ages.
2018-8-25
abdulamex
Pakistan
2018-10-9
abdulamex
Pakistan
Is your problem solved?
2018-10-9
abdulamex
Pakistan
https://rentalcarsuae.com/
2018-10-9
Anumalik
Pakistan
I think the issue has been resolved now.
2018-12-7
snowskier
Flight distance : 246 ft
Portugal
YellowRaven Posted at 2017-5-26 05:21
Dear DJI support,
Excelent question!
2018-12-21
saleemsaif
Pakistan
Thanks for sharing wonderful content. https://www.marham.pk/
2019-1-4
RachelGreen
Pakistan
If you have a 64-bit window, you must install 64-bit DJI Assistant 2 driver
MysticDining.com
2019-1-5
12Next >
