Micro SD Card ???
571 4 2017-3-10
JayOne
is it possible that the p4p can read a 256gb micro sd card even tho the manual says it only reads up to 128gbs
2017-3-10
hallmark007
Flight distance : 7009278 ft
It shouldn't, is 128 not big enough?
2017-3-10
piowoc73
You would need to empirically prove it I guess. From my experience even if recording 4K at 60fps you would need almost an hour of footage to fill 64GB card, so in other words you would need 3 batteries for your P4P to achieve that. Here is a video footage size calculator if you want to play with it: https://www.digitalrebellion.com/webapps/videocalc
Please be aware that by having many smaller capacity cards (e.g. 64GB) you reduce the risk of the card failure and losing your entire work.
2017-3-10
JayOne
hallmark007 Posted at 2017-3-10 09:31
naw im not saying its not big enough..  but i have a samsung 256gb  micro sd card and thinking might want to put it to use
2017-3-10
JayOne
piowoc73 Posted at 2017-3-10 09:35
thanks i would take a look into this and see what happens
2017-3-10
