Remove Before Take Off
2060 13 2017-3-11
Wilddeer
I installed the red parachute cord on the gimble clamp and cover for reminders lol
2017-3-11
Jenee 2
Flight distance : 7852129 ft
I've been a pilot for 30 years and have seen numerous instances of aircraft (full size) taking off with "Remove Before Flight" banners still attached. Just hope your next video doesn't show a red string flapping in the breeze. (just kidding, probably a good idea).
2017-3-11
Haneyca
Not a bad idea. I've thought about putting tape or something on the front of the cover so I would remember.
2017-3-11
SteveDickin
Flight distance : 776007 ft
It's more like "Remove before switching the thing on"  How many times I have sat at my desk to do something in the software and thought NOOOOOOOO I switched it on again without removing the clamp!
2017-3-12
M_str
Belgium
SteveDickin Posted at 2017-3-12 03:41
Thanks, exactly what happened yesterday ...
before flying I check twice
but at my desk, I had totally forgotten ...
do you know if it is very bad for the gimball ?  I had the "gimball overload" alert ...
2017-3-12
fansf13ecec2
My take on this is, if i take it out of the case i remove the gimbal brace (even just removing SD card) and put it back on before putting it back in the case.
2017-3-12
Snap_Shot
Great idea.
2017-3-12
MavicMule
Flight distance : 6329 ft
I used a label maker with a sticker by the power button on each battery "Check Gimbal clamp!"
2017-3-12
NoSale
Flight distance : 460958 ft
Like others here, I've powered up before remembering to remove the gimbal lock.  I've started to put together a similar reminder banner, but think a good idea would be to extend that banner further to actually overlay the battery power switch.  Not sure how to do that yet, maybe going as far as wrapping the banner around the body of the Mavic crossing over the power button, but if you see the banner overlaying the power button, you're a lot less likely to hit the power button before removing the gimbal lock.........
2017-3-12
Chizzy
Quick side question folks. I just received my Mavic, and yes, the second use I forgot to remove the gimbal clamp after start up, but I haven't worked out if the plastic dome is meant to be flown with sometimes or not. I flew with it the first time, thinking it was part of the ride, but noticed wrong reflective glare. Any tips?
2017-3-12
Paul Nordin
Flight distance : 1267953 ft
Chizzy Posted at 2017-3-12 11:26
Either fly with the sun more than 90degrees off your camera's lens direction (ie-behind you), or remove the plastic cover.
2017-3-12
Mavic Jim
Flight distance : 127697 ft
I was under the impression that the plastic gimbal cover always has to be removed in order to avoid overheating.  The cooling-fan intake is under the cover area and the small notch is not big enough to allow adequate cooling.  Am I misinformed?
2017-3-12
High FlyerCokie
Flight distance : 701109 ft
New Zealand
Your Mavic may over heat with gimbal cover on. You can purchase on E-Bay or Ali Express camera shade covers with.
https://www.aliexpress.com/item- ... 08.1000017.2.LNU5id
2017-3-12
Mavic Jim
Mavic Jim Posted at 2017-3-12 16:19
Hmmm...... I just found this excellent article that explains several questions I've seen on the forum.  Looks like my statement above is incorrect.
10 Common Mistakes Mavic Pro Pilots Make
http://forum.dji.com/thread-88220-1-1.html
2017-3-12
