Daroga
Flight distance : 3517287 ft
When you use the DJI Assistant 2, you need to remember that there are two firmware components -> (1) aircraft and (2) remote controller. So you must connect each individually to the usb connection to the computer to update both.
With the Mavic, the firmware is actually copied down and stored to both the RC and the aircraft, so if you have multiple batteries, you may also be prompted to update each battery as the system recognizes that they too need updates.. |
