My 1st Autonomous flight
1767 14 2017-3-15
MerlinL14
Flight distance : 2858 ft
Sat down with the Litchi mission hub on my laptop last night and composed a waypoint mission, first time. Decided on the area of Lyme and Wood Country Park in Newton-le-Willows. This area encompasses 3 fishing pools run by Newton Angling Club, of which I am a member. Chose this as it is relatively open scrub with the odd tree, burn not exceeding 25m.Flight height was 30m and set the crusing speed to 15 km/h, 1.8 km route, 8 min total flight duration. No lag, no signal loss, no issues.
2017-3-15
Taydav
Flight distance : 115328 ft
Where you controlling the gimbal?
2017-3-15
MerlinL14
Taydav Posted at 2017-3-15 09:53
If you meant was I controlling the camera gimbal, then the answer is no. I set a POI and it's altitude, in the profile, set it to "Focus POI". This mission was set with 8 POI's so I could get the P3S to 'look' where I wanted it to rather than just the view of the path it was flying.
2017-3-15
Taydav
Was the pol elevation set at 0?
2017-3-15
Badbobstikibar
Flight distance : 620112 ft
Nice mission. Looked like a good fishing spot.
2017-3-15
hallmark007
Flight distance : 9827923 ft
Good job, first one is always difficult letting it out there on its own, wouldn't call it autonomous though, it's actually auto pilot,
2017-3-15
hallmark007
Good job, first one is always difficult letting it out there on its own, wouldn't call it autonomous though, it's actually auto pilot,....
2017-3-15
DJI-Jamie
Flight distance : 112405 ft
It's good to see you're enjoying the aircraft, happy flying!
2017-3-15
MerlinL14
Taydav Posted at 2017-3-15 12:44
I set the POI altitude to what the true height of each POI was. The ones on the Islands were 5-7 meters, shoreline was 0.
2017-3-16
MerlinL14
DJI-Jamie Posted at 2017-3-15 20:53
Loving the P3S Jamie. Can't fault the hardware, for £400 and change there isn't much if anything to get close to the features.
2017-3-16
MerlinL14
hallmark007 Posted at 2017-3-15 14:37
Autonomous, auto pilot, just semantics hallmark007
2017-3-16
hallmark007
MerlinL14 Posted at 2017-3-16 03:26
Yes your kind of right... but here is the difference (Pilots would not agree with you)
having autonomy; not subject to control from outside; independent:
An autopilot is a system used to control the trajectory of an aircraft without constant 'hands-on' control by a human operator being required. Autopilots do not replace a human operator, but assist them in controlling the aircraft, allowing them to focus on broader aspects of operation, such as monitoring the trajectory, weather and systems.
2017-3-16
MerlinL14
hallmark007 Posted at 2017-3-16 04:09
I got it the first time!
2017-3-16
fans3d7e60a1
Flight distance : 1555344 ft
Just be aware that you understand how smart RTH can abort a mission, But isn't Litchi amazing?
2017-3-16
MerlinL14
fans3d7e60a1 Posted at 2017-3-16 06:09
Read the book, had the T shirt printed, but thanks for the heads up. I have been using Litchi since the debacle that DJI made of version 3.1.2 Go app. First time using the mission hub though, and yes it is amazing.
2017-3-16
