Case modification request to accommodate remote controller
986 5 2015-2-24
christopher.kee
In the case provided, there is a space where the battery is stored that could possibly fit the remote controller as well. The cut out is actually in the shape of the remote and I had assumed that was where it was supposed to be stored. If you could cut out some of the foam in the other side of the case, the remote would fit safely for sure. The photo below shows where I think the remote could be placed. Thanks!   http://imgur.com/C15FZpc
Case/Drone
Case/Drone
2015-2-24
gmhorse
Flight distance : 455505 ft
My case has no problem fitting both controllers as well as multiple batteries. Spin that controller around and fold up the antennas. The second remote will fit the same way right next to it.
2015-2-24
RickRoberts01
Flight distance : 191575 ft
I agree with gmhorse, both controllers fit fine
2015-2-24
gmhorse
Here is a video that shows how to fit everything including both controllers and up to seven batteries into the case for transport. http://youtu.be/we9FymewPQg
2015-2-24
Flymetothemoon
Whoops, ok thanks guys, for the replies. I think I'll delete this post later for fear of death from embarrassment. Thanks again.
This is Christopher Kee btw, not sure why the first post used my name instead of my username.
2015-2-24
Flymetothemoon
gmhorse@gmail.c Posted at 2015-2-25 08:58
Here is a video that shows how to fit everything including both controllers and up to seven batterie ...
Thank you for the video link gmhorse
2015-2-24
