DroneFlying
Flight distance : 10774613 ft
Well, first of all I haven't noticed as many cases of what I call BATTI (Bad Attitude) mode being discussed lately, so maybe it somehow got fixed but even if not it always seemed to be a relatively rare occurrence. I personally haven't encountered the BATTI problem but like you I was concerned with the possibility and came to the conclusion that I basically have two options, though these are based on what may be an incorrect assumption: that I could still control altitude. Assuming that's correct the options (aside from doing nothing) are:
- Increase altitude in the hope that the problem will go away as spontaneously as it appeared and that the aircraft will still be in range so that it you can bring it back or that it will RTH on its own. The risk here, though, is that the altitude increase will allow it to fly away and never be seen again and perhaps even injure someone or something.
- Decrease altitude so that your aircraft can't fly away on its own. Essentially, you'd be forcing it to crash since the assumption is that it's partly or completely out of control other than the ability to change altitude. This ensures that you know where it goes down and might be the best option, especially if you have Care Refresh or something similar.
In practice, though, I don't really worry about it. I like to be prepared but at this point after hundreds of flights I don't consider this a likely scenario, and statistically it seems that you probably will never encounter it either.
