fansa84fe8a4
I somehow doubt it having done enough calibrations to turn green in the face with sundry levels. If I think a new calibration has made any difference, the next time out it's again bad. Even Autopilot has a means to tighten up the altitude deviations from the default of 15 meters down to 5 meters at best. I think their advisement is to not depend on anything less than 10 meters as a safety buffer. Could be the pressure inside the bird, or some thermal drift matter as the electronics warm up, bad or low tolerance hardware, or just buggy software.
Fwiw, on mine I often see takeoffs at zero meters in GO, but landing at -16 meters, or flying around at -3 meters. Really is awful for all the hardware in it, but I don't get excited by it much anymore.
Annoying, but after three birds I just accept the fact it doesn't work that well and plan around it. Autopilot told me to fly it initially with a greater buffer, and then lower the altitude on subsequent flights if it works out. You have to face the fact these aren't military-grade birds we own and fly.
