Black screen on mobile
12Next >
27095 55 2017-3-24
ENG101
Flight distance : 19642 ft
New Zealand
My Mavic has been running but with the latest update Mar 2017., I am now getting a black screen showing no video on my mobile device.
It's weird as the video shows when I start up the Mavic and the app. But after I calibrate the compass and try to take off it goes completely black. I  took off wayway and took a recording with the remote. Checked the recording on the SDcard and it was fine.
So the problem is either with the new firmware on the remote or the new update on the Android app for DJI Go 4.
Has anyone else experienced this on their Mavic or have any ideas on how to get my video back when the app does this?
2017-3-24
Could you please clarify what mobile device you are using?
Have you tried to change another original usb cable to connect your mobile device to the RC via the button USB port?
2017-3-25
ENG101
New Zealand
DJI Mindy Posted at 2017-3-25 00:57
The device is a Mi5s. running Android 6.01 on their MIUI8 launcher.
I'm using the USB-C connector that came with the Mavic connected on the micro-USB port on the left side of the remote if that is what you're referring to as the button USB port.
This device has been working fine with my Mavic for the past 3 months and the problem only started after I ran the latest March 2017 firmware and app upgrades.
The weird thing is that I can see the camera video feed when the app first starts up and connects but it goes black after calibration when I try to take off. The icons are still there and I can access the camera options and Mavic settings.  It's just the Mavic camera feed that is black.
I even turned off the Mavic, remote and restarted the phone and the same thing happened.  The third time I restarted everything the video feed stayed on so I finally managed to get a flight going to capture the view I wanted.  However I lost a lot of time and the missed the camera shot I was after.
I'm worried that this can happen again at any time and would like some help isolating the cause of this  so that I know what to do next time this occurs.
2017-3-25
ENG101
New Zealand
ENG101 Posted at 2017-3-25 01:26
I don't have a 2nd original USB-C cable since the Mavic only comes with one.
However, I don't think it's the cable since I can still use the options on the screen to change the settings and the camera feed comes on initially before going black.
2017-3-25
fansc8995910
Hi guys, new to the forum! I just received the Mavic but I get a black screen using the app. I have tried a tablet and a Samsung s6 and both show the same problem. I also tried to shoot some video and photos  and both show completely black. Am I missing something really basic or is this an issue? Thanks so much for your advice as I am looking forward to seeing the mavic fly
2017-3-25
fansc8995910
Hi, just to add to my previous post. This issue occurred both with both firmware updates (original and most recent). Thanks for your help!
2017-3-25
fans44cb1ddb
Flight distance : 210 ft
I have been flying my Mavic every day for a week and yesterday was the first time I experienced a loss of video.  As I started to bring it back in, the video came back.  I'm using an iPhone.
2017-3-25
rydfree41
Flight distance : 153268 ft
Sounds like a bad USB cable or port . Switch cable and use the other port and report back .
2017-3-25
M Stuart K
Flight distance : 1267717 ft
fans44cb1ddb Posted at 2017-3-25 06:37
I wonder is there something really connected to this issue.  I posted the message below earlier as I thought the controller was killing the battery on my Ipad.  At takeoff the the ipad had over 50 percent battery and after about 10 minutes of flying.  Since that post I remembered that I had something similar happen with my iphone 6 plus a few weeks ago.  The iphone shut down at 65 percent battery.  This is my original post below:
Has anyone experienced their Ipad Pro shutting down at around 20 percent battery power left while flying their Mavic?     I had an interesting thing happen today while conducting a long distance flight along the shores of the Chesapeak Bay in Maryland.  I was nearly 2 miles out when my the screen went dark on my Ipad.  No; it was not that low when I started flying, it was nearly 50 percent and I had only flew about 30 percent of one battery when it started shutting down.
I decided to not panic and looked at the screen of my controller and the Mavic was hovering in place at a resonable altitude just off shore.  I let it hover while I rebooted the Ipad and as soon as it booted up it shut down again-3 times I tried before I hit the return to home button and just waited.
After I visually landed the Mavic I disconnected the Ipad and booted it up again and it remained powered on this time with battery power at around 20 percent. I switched to my Iphone and tried again and continued to fly 3 batteries with it with no problem.  My questions are: did it shut down at 20 percent primarily because it was connected to the app? Or, is there a particular setting in the Ipad that shuts it down when useing an app such as the Go4?  I have read posts where the app disconnects but I think this is different because the whole device shut down!  One thing for sure, its a dam good thing I had my home point set when it happened because the aircraft was much too far away to pilot it back visually.  Any assistance will be appreciated.
2017-3-25
ENG101 Posted at 2017-3-25 01:32
You could try to use a original USB cable  (the cable you use to charge your phone) to connect your phone to the button USB port instead of the side micro USB port.
2017-3-27
M Stuart K Posted at 2017-3-25 07:13
The app will not cause the device shutting down.
Please try to full charge your mobile device then test again.
And please ensure that you do not have any programs running in the background.
2017-3-27
fans9d372f24
Flight distance : 5010 ft
Switzerland
I have the same problem , after the last update, I am getting a black screen..... any solution out there or from DJI ?
2017-3-30
fansdff7922f
I am having the black screen issue also. I haven't had success seing a picture from Camera to phone real time. I just got drone a few days ago. It flies, but I can't see anything. I tried my phone USB chord, but still nothing. Has anyone with this same issue gotten it to work? I am using an Iphone 5s.
2017-4-15
fansdff7922f
fans9d372f24 Posted at 2017-3-30 06:42
if you find a solution please let me know. I have the same issue.
2017-4-15
strick2210
Flight distance : 119485 ft
Same thing here. I just got my mavic back from repair too. It was working before I updated to the latest firmware. I'm reverting back to .400. Hopefully that puts it back into the state it was before I did the latest firmware update.
2017-4-15
strick2210
Update - Fixed. I reverted back to .0400 and still had the issue. This was on my S7 Edge running the latest DJI Go4 app and latest 7.0 android for my phone. I never had this issue until today. So I shut everything down plugged in my work phone which is an iphone 5s. Video is working now.... Odd... So I switched the cable again back to the S7 Edge micro usb that came with the mavic and I still didn't have video. What I did to fix my video on my S7 was just unplug the cable from the phone while the Mavic and controller was powered on and poof, video starting working on my S7 Edge again. I shutdown and restarted a few time and video continues to work on my S7 edge. Granted I'm on .0400 now and I haven't went out and flown yet, but it seems like unplugging the cable while the controller and Mavic was on did the trick for me. Now I'm wondering if I should go back to the latest firmware again.... hmmmm.
2017-4-15
blas2095
Thanks for sharing. I tried unplugging the cable while on and still nothing.
2017-4-15
Webcruise
I also had this proble the last times I was flying. (iPhone 6s). While flying closed the app and restarted and picure came back. The issue does not happen always at the same time. I talked to the german service desk and they told me to reinstall the app. I did not have the chance to try if it workes now.
2017-4-15
Webcruise
rydfree41 Posted at 2017-3-25 06:51
Could be the reason rydfree41, but why does the video picture returnes when I restart the app during flying without touching the cable? This incident really is annoing becuase its not reproducable.
2017-4-15
strick2210
I went back to .0600 firmware and my video still works on my S7 Edge. I guess I will caulk this one to maybe a bad cable seeding to the phone or the controller. I will update if it comes back.
2017-4-16
Iamchrisworkman
I am experiencing the same 'black screen on mobile' issue also. I'm using an iPhone 6. I'm in process of downgrading to .0400 right now, as well as down grade the remote if that's possible. Crossing my fingers the video comes back.
2017-4-16
Iamchrisworkman
No luck. Downgrading didn't work. =(
2017-4-16
justrick
Had the same issue with brand new Mavic Pro and iPhone 6s Plus. Updated firmware, flight worked just fine. Solution: Close the app and restart. Problem solved!
2017-5-15
MXM DJI
Flight distance : 202408 ft
PLEASE HELP! Before the last update all perfect with many good flights, but after installing 01.03.0700 I can not see anything, black screen (not photo, not video) but the flight and gimbal is correct. I have returned to previous versions and I have not recovered images again.
My Login is correct.
Original cable.
Phone: LG G4 android 6.0
This is causing me a lot of headache because I tried everything, help please.
2017-6-5
MXM DJI
Original cable.
2017-6-5
Lurker
Flight distance : 287815 ft
Im having the same problem with iPhone 7 Plus (latest iOS version, Go App and Mavic firmware).
Ive tried multiple (original Apple, original DJI and aftermarket) lighting cables and still get sporadic camera disconnects.  This has happen in multiple flight locations so I am ruling out RF interference.
2017-6-5
fans5bcee644
I am having the same issue, brand new drone. I have tried it with the s8+, s7 edge, and tablet. Everything up to date.  I have tried the cable that it came with and also used my phone cables. This is a big issue and should get fixed ASAP!!. I heard so many good things but this is not good. I cannot believe DJI cannot see this issue.
2017-6-5
Lurker
Im going to wait for another round of firmware updates, if the problem does not fixed, I will open a support case.
2017-6-6
Black Lotus
Yesterday I talk to two different support personnel from DJI, I let them know of this problem. Was told they never heard of it. I sent them the links to 3 open forums on this issue. They said most likely we are using devices that are not supported so they cannot help. So I listed the devices I have tried, S8+, S7, Iphone 6, and Asus Tablet. I also again pointed them to the forums with others having same issues with other devices.
I also sent this off of their site " os: iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus, iPhone 7, iPhone 7 Plus, iPod touch 6, iPad Pro, iPad Air, iPad Air Wi-Fi + Cellular, iPad mini 2, iPad mini 2 Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 3, iPad mini 3 Wi-Fi + Cellular, iPad mini 4, and iPad mini 4 Wi-Fi + Cellular. This app is optimized for iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus, iPhone 7 and iPhone 7 Plus."  List of support devices. Which two of them told me s7 is not supported.
Android: Samsung S7 edge, Samsung S7, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Samsung tabs 705c, Ascend Mate 9, Ascend Mate 7, Huawei Honor 8, Huawei P8 Max, Vivo X7, Xiaomi 5, MI 3, Google Nexus 6p, Nexus 9, Google Nexus 7 II, LG V20, Sony Xperia Z3, Smartisan T1.
*Support for additional Android devices available as testing and development continues.
Well by now i was very frustrated I felt these guys don't really care to address the issue or even believe that's the last update could have caused anything.  So bottom line, There was no help and I am using the wrong phones.
Now I have tried their cables and the ones from the phones. I also made sure Everything is up to date from their website. I have tried to uninstall delete all files and reboot, reinstall and still nothing.
Anyone else has had better luck
2017-6-6
Black Lotus
Update: Got a new Drone yesterday. Did not install the update and works fine on the S7 and S8+ On the S7 I ran the update and restarted, now Black screen. There are no other apps running.
So it is something with the update that is causing it. I did not run the update on the S8+ cause I still want to be able to use it. Tonight I will try it on the iPhone 6
2017-6-7
fansc4c8a652
China
The reason why is my iPhone screen black can be various: stuck on recovery mode, OS update failure and more. To fix the black screen issue, you can reset your mobile phone back to factory settings as it was. You can follow below:
Step 1. Open iTunes on your computer
Your iTunes should be the latest version installed on your computer.
Step 2. Connect your iPhone 6 with your computer by using USB cable
Step 3. Go to "Summary" homepage and then select “Restore iPhone” option
Step 4. Click on the "Restore" button
2017-8-10
Danjahmouse
Flight distance : 163474 ft
New Zealand
I've had my Mavic for 8 months without any issues, all updates fine, my issue with the black screen only started yesterday. Uninstalled app and reinstalled. First the issue only started everytime I recorded video, photos were fine but after reinstalling it now only happens when I stop recording SOMETIMES gggrrr.
2017-8-12
Danjahmouse
New Zealand
Oh and when I reestablish a connection and video feed it tells me that there is no connection, RTH.
2017-8-12
rhorne
I've just had the exact same issue described above and I'm certain it's something to do with the firmware.
I've had my brand new Mavic Pro for a fortnight now and used it 3/4 times without any hassles whatsoever. I've just taken it out for another flight and was prompted to upgrade the firmware. I did so and almost immediately afterwards I had the black screen issue. Restarting the app seemed to fix it for about 20 seconds then the black screen kicked again.
This didn't happen once before the firmware upgrade.
2017-8-13
Ray_Dunakin
Is the screen going black suddenly, or does it gradually get darker?
2017-8-13
kou
China
I have the same problem. Why is my iPhone screen black?! How can I get rid of this situation? Some people tell me that iPhone black screen is commonly causes by iOS update or downgrade failure, jailbreak or hardware broken. But my iPhone does not belong to any of these issues. Should I hard rest my iPhone? Can I restore iPhone without iTunes?
2017-8-23
R_Adams
Flight distance : 9144 ft
Hello
I created a post about a similar issue and the iPhone 7+ in the DJI Go section; https://forum.dji.com/thread-110319-1-1.html
Maybe it is similar to your issue?
I have a new cable on order but I experienced the issue right after the upgrade to 4.1.5 and it persists with 4.1.7.
Thanks.
2017-8-26
djiuser_QVRN0kI
I found that if you reset the camera settings, the picture returned. I am using an iPhone 6s.
2017-8-27
Wizzy 8
Flight distance : 2595 ft
Vietnam
djiuser_QVRN0kI Posted at 2017-8-27 17:26
I have tried that but still black screen, i have also uninstalled dji go 4 and reinstalled and tried same thing black screen with HUD details but no video signal.
2017-8-28
RjRA2
Flight distance : 63894 ft
Hello,
Yesterday I got my new Mavic and first thing I did was charge all the batteries then connected it my computer and upgraded all firmware for the remote and drone.  I also did all the calibrations before taking it out for a flight.
My first flight was probably 5 minutes long and my image on my NEW iPhone 7 went black on me.  I was able to get it back to the ground without any issues.  Once back the image and restarting everything the image came back.  My second flight ended with the same result, my image went out after flying for maybe 5 minutes and I returned to home.
What is going on?  The drone, remote and my iPhone are brand new and up to date on the latest firmware.
2017-8-29
12Next >
