I can't even start the motors using the combination stick command ALTOUGH I was able to start them once while moving the sticks in some random fashion. An indication I thought that I seriously need to calibrate the controller sticks.
Sadly I am finding it impossible to do so (I have been able to calibrate the controller sticks under previous firmware / DHI Go 4 app versions). I am using current firmware and DJI GO 4 version. I have tried two different Android devices. I have tried many dozens of times over the last couple of weeks. The closest to a completed stick calibration I have managed is to do is right stick complete and about 80% of the left stick before the dreaded message "The last remote controller calibration has been time out, the calibration state will be reset". Most attempts do not get nearly this far.
There's no problem centerng the sticks to begin calibration. Typically the left stick won't register even the first dot so I have to start with the right stick. I am sometimes able to eventually finish that one before timing out on the left stick but always there are major delays holding the stick in a certain position for 30 seconds or so before the dot finally moves again. It seems every attempt has different "sticking" places.
I have no idea why DJI wouldn't provide sufficient time to calibrate. Perhaps my controller is broken (I have had only 2 flights!). Is it necessary to start calibration with the left stick? Why did DJI change the calibration procedure (slowly filling in the gaps in the previous version was a pain but far less than it is now).
Well wouldn't you know it, just after I posted this message I tried a few more times and I finished the stick calibration! But I still can't use the proper CSC to start the motors - I did start them again with some random stick movement (I think up and out) but obviously reluctant to try flying when up might be down, left might be right. Interesting though that down left stick did correctly shut down the motors.
Derodeo Posted at 2017-3-26 21:10
It was super-painful to calibrate those sticks - I had to watch a few videos of people doing it. They made it look a lot easier. My take away from calibrating those sticks is that it was a fluid motion trying to hit those blue dots - and it was flaky as heck.
Anyhow, sorry to hear about yor problem - hope it gets resolved.
DJI Mindy Posted at 2017-3-27 00:14
Could you please make a short video of the calibration issue?
Besides, here is the video tutorial for your reference.
The app told me I had successfully calibrated the sticks (after maybe a hundred freaking tries!!!) so I apologize for not wanting to risk starting over by making a video of the ordeal. But the issue is now that I can't start the motors using the normal CSC (sticks down and in/out). I can start them using up and out (I think that was what worked for me) - does this mean my stick calibration is still faulty or that trying to fly my drone will result in a likely crash as the sticks won't react normally? I'll have to try it tomorrow and see for myself (flying a drone in most of Canada must be done in secret!)
I do strongly recommend DJI provide more time for a user to calibrate before timing out. I know how calibration is done, indeed I have done it with no real problems before under prevous software versions. With more time I could have probably done it again without the extreme aggravation and swearing.
Derodeo Posted at 2017-3-27 15:47
Sorry for my late reply.
Do you still cannot start the motors by using the CSC?
I just received my Mavic Pro Platinum, and I cannot seem to calibrate the sticks. I'm having the same issue described above: the calibration keeps timing out.
AerialAmphibious Posted at 2018-3-13 16:36
Have you checked the tutorial video I posted above to make sure the steps are correct? Besides, please make sure the firmware of RC and aircraft is matched.
When calibrating the RC my right stick never seems to register a return to center. It says it is 6% out of center while at rest. It still allows my to finish and claims calibration was successful. Any Ideas?
Normally you don´t need to power on the AC during stick calibration for the RC. On my P3S it goes rapidly to the end and whole positions of both 2 sticks and gimbal wheel are calibrated.
I don´t know much about Mavic but the procedure should be the same.
