RicardoGray
Flight distance : 4356421 ft
capbat Posted at 2017-3-29 10:03
I have checked with the DJI Go App (Android) and it says I am on 1.10.90 but still, reading the LOG_AB files is confusing!.
Comments?
I am no expert, but I think the numbers on the left in your log file are referring to different hardware components. Seems like I have read this before. I do not know what they actually refer to. But, I would go for installing the latest firmware and not worry about skipping one. Some time back if you had a version that was I believe V1.3 or older, you couldn't jump right up to the latest one and had to go one by one, but I think it is not an issue with the later versions. Along with those later releases came the ability to upgrade through your WiFi and the app instead of having to use the sd-card. Someone might be able to explain what the comments are in your log file (DJI-moderator) or some more experienced person. I look at these when I upgrade, but honestly I have never had an issue, so I don't really dive into it that much. I just look for the "Success" and forget about it, or if it wasn't successful, I do it again. |
